DIY plasma table recommendations on design
11 Jul 2022 05:38 #247054
by pmaskale
DIY plasma table recommendations on design was created by pmaskale
All,
I have been wanting to build a plasma table for a while. The table will be based around a heavy duty 2.5' X 5' outfeed table (dumpster find).
My question is...
What do you think about running the gantry arm across the 5' section giving me 4+ feet of gantry. So the entire gantry arm would move back and forth 2.5' and the torch would run along the 4.5 foot gantry. This would allow me to put a 4x8 foot wide sheet in and cut all the way across the 4' length like a shear. I would need 2 ball screws down the 2.5 foot sides, and likely two servos, to keep it square. Working with only 2.5' stock widths seems like a significant limitation while cutting.
Do you see any other issues with this design? Has anyone done this(opinions)? Maybe worth it, or just overly complicated?
Thanks for the input
My question is...
- Thank you received: 5984
11 Jul 2022 11:28 #247066
Replied by tommylight on topic DIY plasma table recommendations on design
I always do small plasma machines with a wide gantry, 2 meter wide by 1 meter.
No screws for plasma, to slow and dust ruins them.
Also if it is your first machine, no servos, steppers are easier to shield from interference.
Have a look here for ideas:
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
Time to create page: 0.473 seconds
