Wiring the Hypertherm interface cable
- Aldenflorio
- Topic Author
- Thank you received: 13
01 Jan 2023 15:26 #260706
by Aldenflorio
Wiring the Hypertherm interface cable was created by Aldenflorio
I’m having a bit of trouble confirming that the wiring set-up I have come up with is correct for the hypertherm 45xp plasma with the interface cable going to the Mesa 7i76e board and the thcad-10 card. Would someone be able to look at this and help me please?
along with that, do I need the interface cable with the voltage divider for the thcad-10?
- Thank you received: 5984
01 Jan 2023 15:56 #260708
Replied by tommylight on topic Wiring the Hypertherm interface cable
That looks OK, if you are sure there is a divider on the 45XP, some do not come with it.
Also, do not connect the shield/ground to THCAD, at least i never do.
THCAD10 will work.
THCAD10 will work.
- snowgoer540
- Thank you received: 753
01 Jan 2023 16:52 #260713
by snowgoer540
Replied by snowgoer540 on topic Wiring the Hypertherm interface cable
The 5V and GND connections for the THCAD are not correct. You're also missing the ground connection for the inputs/field power.
I'm a bit confused as I thought you've already made a plasma table in the past.
While looking for a diagram to point you to I came across this: forum.linuxcnc.org/plasmac/45078-plasmac-thcad-10#234455
01 Jan 2023 18:21 #260718
Thank you.
Sorry, i did not look at that part at all, checked the numbering and it was Ok so i moved on.The 5V and GND connections for the THCAD are not correct. You're also missing the ground connection for the inputs/field power.
Thank you.
- Aldenflorio
- Topic Author
01 Jan 2023 20:04 #260726
by Aldenflorio
Replied by Aldenflorio on topic Wiring the Hypertherm interface cable
I have in the past, and I am spot for some seemingly basic questions. Though I tend to start the tables the research, wire it based on my research, then forget to write it down.
so now I’m going back with what I removed and making a descriptive guide to wiring. I’ll post that up here sometime soon to make sure everything is right.
my first table used a proma and that worked good but my second one I used a thcad-10 and I never got it fully working because that diagram confuses me.
I apologize.
I apologize.
- snowgoer540
01 Jan 2023 20:50 #260730
by snowgoer540
No apology necessary.
The THCAD-10 portion of the diagram you posted back in February for the 7i76 is correct (and would be right for the 7i76e as well). Save for the fact that "Ground to post" to the SHIELD connection on the THCAD may not be necessary. In my case it made the voltage noisy when viewed with HALSCOPE so I left SHIELD unconnected, which is perfectly acceptable.
I apologize.
01 Jan 2023 20:59 #260731
I always make a series of tables of the inputs nad outputs and always update it before attaching a wire.
Replied by rodw on topic Wiring the Hypertherm interface cable
- Aldenflorio
- Topic Author
02 Jan 2023 16:29 - 03 Jan 2023 16:59 #260774
by Aldenflorio
Okay thank you for understanding. I suppose what confuses me the most is pin 14 going directly to field power as well.
if pin 14 is receiving field power won’t it negate the idea of an input or output being produced? This is my updated diagram. Does this seem right?
Last edit: 03 Jan 2023 16:59 by Aldenflorio.
- Aldenflorio
- Topic Author
02 Jan 2023 17:20 #260778
by Aldenflorio
That’s a great chart! I’ll do that thank you
- Aldenflorio
- Topic Author
03 Jan 2023 16:59 #260851
by Aldenflorio
Time to create page: 0.219 seconds
