PlasmaC THCAD-10
- Aldenflorio
- Thank you received: 15
10 Feb 2022 03:05 #234455
by Aldenflorio
PlasmaC THCAD-10 was created by Aldenflorio
- phillc54
- Thank you received: 2100
10 Feb 2022 03:22 #234458
by phillc54
Replied by phillc54 on topic PlasmaC THCAD-10
Something along the lines of:
hm2_5i25.0.7i76.0.0.input-00
hm2_5i25.0.7i76.0.0.output-00
- Aldenflorio
10 Feb 2022 21:59 #234531
by Aldenflorio
Replied by Aldenflorio on topic PlasmaC THCAD-10
I have the arc OK which is in pin 10, then I have the floating switch which is pin 2. I got those from the hal. I just am not sure where to find what exactly to type in for arc voltage, or torch On.
- phillc54
10 Feb 2022 23:00 #234534
by phillc54
I think arc voltage would be hm2_5i25.0.encoder.00.velocity
Torch on would be whatever output pin ypu have wired.
- Aldenflorio
15 Feb 2022 22:14 #234984
by Aldenflorio
I TRULY NEED HELP!!
I cannot figure this out.
arc voltage-??? I tired what was suggested but I get error messages saying it doesn’t exist
Ark OK- hm2_7i76e.0.7i76.0.0.output-10
torch on- ???
floating switch- hm2_7i76e.0.7i76.0.0.input-01
torch on- ???
- phillc54
15 Feb 2022 22:16 #234985
by phillc54
Can you post an attachment with all the hal files and the error messages.
- Thank you received: 7478
15 Feb 2022 22:39 #234988
Float switch is alo INPUT so the above should work.
Use "hal configuration", on the left side select "pins" then the card (7i76) then 0, then whatever comes next until you find "encoder", click on it, now on the right side check and write the pin, it should be something similar to what PhillC mentioned above, enter EXACTLY that pin for "arc voltage".
Replied by tommylight on topic PlasmaC THCAD-10
ArcOK is INPUT
torch on- ???
- Aldenflorio
16 Feb 2022 00:01 #234993
by Aldenflorio
Where is “Hal configuration”? Do you mean select mode 0?
- phillc54
16 Feb 2022 06:31 #235013
by phillc54
All the .hal files in the config directory or you could compress the config directory and post that.
- Aldenflorio
19 Feb 2022 18:55 #235342
by Aldenflorio
I’m sorry I’ve been away. I’ll post the compressed file of my base machine set up. I again am using the same wiring as the picture. My floating switch is pin 1, my arc okay is pin 10. I found afc voltage to be hm2_7i76e.0.encoder.00.velocity
i still don’t know what to put for torch on
Time to create page: 0.201 seconds
