OpenPnP with LinuxCNC via linuxcncrsh?
26 Apr 2023 00:46 #269931
by blazini36
The pnuematic thing does not equate. Think of a see-saw where home is center Advancing positive retracts 1 person and advances the other person. Homing negative does the opposite.
If you have switches at the extremes of both sides then one head is fully extended when the other is fully retracted. If XY is in some willy nilly position how do you home Z and guarantee 1 nozzle does not hit something on the table?
If your switch is in the center, how does Z take the shortest path to center if the machine does not know where center is because it has not been homed yet? If a home switch is in the center how does it find it without hitting limits first and going back to my last point?
In the above cases, I think it's safer to home X and Y to a neutral position first, maybe that Z center switch dissallows XY homing unless it is tripped, that is another safe option but you would still want to bring X and Y to a neutral corner first. The only time I think it is best to home Z on this type of head first is if you do have absolute position feedback on it.
So I mentioned the Potentiometer for absolute position feedback. In that case it actually might be best to home Z first because you can know exactly which direction it takes the shortest path to center, there's no posibillity of extending one head during Z homing unless the pot broke. If the pot breaking or misreading is a worry, than you can get into all kinds of complicated scenarios with both a pot and a center switch but I'm sure you get the point.
Replied by blazini36 on topic OpenPnP with LinuxCNC via linuxcncrsh?
Yeah you are missing something. We are talking about homing 1 motor that controls 2 heads opposing each other. On a Mill it's pretty much guaranteed that the direction Z will move during homing is the safe direction. That is not the case here.-Why would anyone assume the Z axis home to be down? It is up, always and on every machine i came in contact with.
-Even if using pneumatic Z axis, it should have homing disabled if no air pressure
Or am i missing something?
I have yet to see a machine, any machine that does not home Z first.
I am sure there might be some strange machine that does that, but i can not think of one.
26 Apr 2023 00:59 #269932
Replied by rodw on topic OpenPnP with LinuxCNC via linuxcncrsh?
I think I would still home it to the top and then use your work offsets to select which extruder was in use. Any height difference could be accounted for then
And yes home Z first.
26 Apr 2023 01:04 #269933
by blazini36
It's like an echo chamber in here. Understand the issue first, then offer suggestions
Extruder? I think you completely missed the point.I think I would still home it to the top and then use your work offsets to select which extruder was in use. Any height difference could be accounted for then
26 Apr 2023 01:46 #269935
by phillc54
Replied by phillc54 on topic OpenPnP with LinuxCNC via linuxcncrsh?
LinuxCNC would know which direction to home dependent on whether the home switch was activated or not when homing commences.
26 Apr 2023 02:11 #269937
by blazini36
Definately getting away from the point of the post......lets bring it back now.
Assuming you had a home switch that stayed in contact the whole time (or at least most of) it was beyond one side of home. The picture I posted was just an example of the way one side extends while the other retracts. Most of them are belt loops and are hard to add home switches to (like mine)LinuxCNC would know which direction to home dependent on whether the home switch was activated or not when homing commences.
- plhsystems
26 Apr 2023 08:08 #269956
by plhsystems
Replied by plhsystems on topic OpenPnP with LinuxCNC via linuxcncrsh?
I had previously mentioned that I was looking for an alternative to the see-saw approach because of the homing problem. With any system, you can't move anything unless you know it is safe to do so and driving Z down on a PNP without knowing where the axes are is unsafe.
26 Apr 2023 09:08 #269958
by blazini36
Yeah I spent the last 5 posts trying to explain that. Anyway, the potentiometer approach seemed like such a good idea I changed 2 of the analog inputs on the PCB I'm working on from vacuum sensors to connectors for a potentiometer.I had previously mentioned that I was looking for an alternative to the see-saw approach because of the homing problem. With any system, you can't move anything unless you know it is safe to do so and driving Z down on a PNP without knowing where the axes are is unsafe.
- plhsystems
26 Apr 2023 09:58 - 26 Apr 2023 09:59 #269962
by plhsystems
I think I like your previous idea of having a switch permanently made when the axes is not at home and someway down. That way, you could use two switches (one for each side) and have the centre point where neither switch is made and hence home. So homing would be simply:
And as long as the switches are at the same height, finding the true centre point wouldn't be too hard, just halve the distance from when the switch on one side releases to when the switch on the other side makes.
- See which switch is made
- Move that side so that it goes up
- Stop when the switch in no longer made
Last edit: 26 Apr 2023 09:59 by plhsystems.
- Thank you received: 5944
26 Apr 2023 11:02 #269964
Replied by tommylight on topic OpenPnP with LinuxCNC via linuxcncrsh?
1 switch + home_offset will home it anywhere, including in the middle.
As for precission, it uses a stepper with a pulley directly driving heads, so even a cheap microswitch will be more precise than the drive parts.
Using an optical switch and a 0.9 degree motor seems better for accuracy, as there is no need for a lot of torque, and this is for very small parts.
- plhsystems
26 Apr 2023 11:05 - 26 Apr 2023 11:31 #269965
by plhsystems
Excuse my lack of knowledge, but I'm not sure what you mean by home_offset, unless you mean you move to the switch and then offset from the switch, but this won't work. In this instance the home switch is in the middle of the axis, if you don't know where you are on that axis, how can you know which direction to move to get to the middle? You can't have the switch at either end of the axis because this risks plunging one of the nozzles into the bed.
Last edit: 26 Apr 2023 11:31 by plhsystems.
Time to create page: 0.099 seconds
