Probe Basic probing without Z-Axis?
- figure_of_disguise
- Thank you received: 6
15 Apr 2023 17:33 - 15 Apr 2023 17:34 #269132
by figure_of_disguise
Replied by figure_of_disguise on topic Probe Basic probing without Z-Axis?
Hello,
i didn't read in the forum for a long time, sorry for that Chris!
Awsome work you did - i'm very thankful for that, love it!
I thought noone cares about that - but sometimes it's useful.....
I will try to update Probe Basic tomorrow - didn't get the Updater to run yet.
....something is wrong - i check tomorrow.
Thank you very much Chris!
Martin
Martin
Last edit: 15 Apr 2023 17:34 by figure_of_disguise.
16 Apr 2023 04:27 #269186
by Lcvette
Replied by Lcvette on topic Probe Basic probing without Z-Axis?
The updater no longer works, anything pre linuxcnc 2.9 is no longer being supported, you will want to update by going to Debian 12 and using the .deb installation method in the sticky section. Also be sure to update your configs with the py3 config doc also in the sticky section.
Thanks!
Chris
Thanks!
Chris
The following user(s) said Thank You: figure_of_disguise
16 Apr 2023 12:20 - 16 Apr 2023 12:21 #269209
......ah,ok!
That's not done in 5min
I changed almost everything in my current system (linux & linuxcnc), maybe a new "clean install" is a good idea....
I read the latency also improved with Debian 12 & 2.9, that's a fine thing too....
Thanks Chris, i will write back when i finished the upgrade - but maybe takes some time
Martin
Martin
Last edit: 16 Apr 2023 12:21 by figure_of_disguise.
17 Apr 2023 08:01 #269284
Replied by rodw on topic Probe Basic probing without Z-Axis?
These instructions of mine should let you get Bookworm up with minimum fuss
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
18 Apr 2023 17:17 #269377
Thanks rodw, that worked fine....
A Probe Basic Sim is also running fine.
I installed it on an old HDD for testing, so i can run my machine just changing to SSD....
Now i have to import my ini & hal etc.....
Martin
Martin
12 Jun 2023 16:51 - 12 Jun 2023 16:53 #273403
Hello,
had no time to play the last weeks, sorry!
i have an issue...
1. probe basic sim is running
2. example machine is running in axis
3. but when i want to start probe basic with my ini i have got an error:
can`t execute display programm
.....i was not able to fix that - any idea?
I'm so happy, i have installed it on an old HDD
Martin
i have an issue...
Martin
Last edit: 12 Jun 2023 16:53 by figure_of_disguise.
14 Jun 2023 03:46 #273530
by Lcvette
You need to perform the conversion for your config. Conversion doc linked below:
forum.linuxcnc.org/qtpyvcp/48401-configu...-for-probe-basic-py3
15 Jun 2023 17:20 #273633
Hello,
...i did that several times, also created a new machine just to test - no luck!
But now i have a funny question:
...is it possible, that the new system don't work with a "StepConf" created machine?
Martin
Martin
16 Jun 2023 20:26 #273715
by Lcvette
never tried that, always used pncconfig so not sure. but the important thing is that all of the correct settings are there and the installation is done correctly/
05 Apr 2024 08:41 #297628
Hello,
tried it this week again with the last version.....
Everything works fine.....love it!
No idea why it didn't run last year, maybe patience is the trick
I found an issue and will open a thread for that.
Thank you all for your great work around linuxcnc!!
Martin
Martin
The following user(s) said Thank You: tommylight, Lcvette
Time to create page: 0.193 seconds
