Developer Install for Probe Basic Py3 (For UI Development Only)
10 Mar 2023 05:11 #266260
by Lcvette
Requirements:
Debian 12 Bookworm (or later)
Linuxcnc 2.9 (or Later)
This is the Development installation for QtPyVCP and Probe Basic:
It is not recommended to run a machine with this installation as it is a run in place inside a virtual environment (venv) as python calls it. It may run just fine but i have not tested it so have no idea if the venv will introduce any odd latency issues. This is the new norm for programs installed with pip. This installation is very simple to install and will set you up with the development tools needed to work on probe basic and contribute through your favorite tool for handing your repositories.
The installation instructions are found here:
github.com/Lcvette/qtpyvcp-bookworm-installer
and follow along video here:
The following user(s) said Thank You: TurBoss, tommylight, elovalvo, spumco, CNC_ANDI, nwallace, Unlogic
10 Mar 2023 05:47 - 10 Mar 2023 05:47 #266263
Replied by rodw on topic Developer Install for Probe Basic Py3 (For UI Development Only)
Tested and confirmed its working...
Last edit: 10 Mar 2023 05:47 by rodw.
The following user(s) said Thank You: Lcvette
10 Mar 2023 20:24 #266329
by spumco
Replied by spumco on topic Developer Install for Probe Basic Py3 (For UI Development Only)
OMG, that was stupid easy.
Confirmed working on a Win10 Virtualbox VM w/ Bookworm.
13 Mar 2023 11:57 - 13 Mar 2023 12:09 #266540
by CNC_ANDI
Replied by CNC_ANDI on topic Developer Install for Probe Basic Py3 (For UI Development Only)
having error
Last edit: 13 Mar 2023 12:09 by CNC_ANDI.
13 Mar 2023 16:27 #266567
by Lcvette
Replied by Lcvette on topic Developer Install for Probe Basic Py3 (For UI Development Only)
In the development installation, the provided launchers on the desktop must be used.
if you want machine control installation you must use the .deb installation in the sticky thread here:
forum.linuxcnc.org/qtpyvcp/48373-qtpyvcp...llation-files-inside
The following user(s) said Thank You: CNC_ANDI
13 Mar 2023 16:33 #266569
by CNC_ANDI
i used the luncher on the desktop... but become this error
13 Mar 2023 16:37 #266570
by Lcvette
is this on deb 12?
14 Mar 2023 14:03 #266662
by CNC_ANDI
yes using a clean debian bookworm with xfce
14 Mar 2023 16:17 #266670
by Lcvette
looks like a conflict here:ERR| vtkShaderProgram (0x64906c0): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
you need a graphics card that support GLSL 1.50 or greater
14 Mar 2023 17:44 - 14 Mar 2023 18:58 #266679
by CNC_ANDI
ok i will check this... i will put in a pcie graphicscard
edit: Works now fine! Many Thanks you are great!
Last edit: 14 Mar 2023 18:58 by CNC_ANDI.
Time to create page: 0.094 seconds
