qtdragon - probing issues
- Thank you received: 3900
02 May 2023 11:52 #270477
qtdragon - probing issues was created by rodw
Well, I got the GUI sorted, now on to trying to make something! I ran into issues probing so I will report them here and apend additional ones I find:
Basic Probe
1 Outside corners works perfectly. I think I tried them all (at least 3 anyway)
1. Outside corners - probe to edge works perfectly.
2. Outside corners - probe to surface fails, Probe goes nowhere
3. Boss and pocket. Pocket does not work on a 10mm hole (I even added a hint) Seems that its not doing a G38 move when it hits the first edge (Probe triggered while not probing error)
Versb.y Probing
Not tried. Will try it and report back. Really need that surface probe to work
Basic Probe
Versb.y Probing
- Thank you received: 2114
03 May 2023 03:49 #270535
Replied by cmorley on topic qtdragon - probing issues
I'll try to setup a test on the weekend.
there was a request to modify things here and. I'm not sure they got looked at:
forum.linuxcnc.org/qtvcp/46615-probe-basic-in-qtdragon?start=10
Obviously better docs are needed. I am hoping someone who uses the routines could help.
Chris
Chris
03 May 2023 04:22 #270537
Replied by rodw on topic qtdragon - probing issues
versb.y
I was able to probe to surface with vers.by.
Outside corners seems OK.
Its a bit of a nuisance as you have to swap probe screens between corners and surface
If I probed to surface and told it to raise 10mm for safety at the end, probing to the corner seemed to probe at the surface level of the material.
It need to drop a bit lower (12-15mm say) but I could not get it to seperate the finish height from the side probe travel down before probing
changing some parameters got me closer to probing a 10mm hole but it errors again
It seems the circular pocket rapids for a while before probing. his makes no sense, I would have thought the probe should drop in the hole and then immediately start probing so it never can hit the edge on a non probe move.
The ideal solution would be to fix the probe to surface on basic probe.
I think the workflow should be:
1. move to near a corner (top left for me)
2. Probe for surface which retracts to a safe height after probing
3. Probe for the corner but allow the probe to descend by safe height + some number
And also like the other thread, I cannot get a manual tool change to work. Nothing displays.
I worked through the docs again carefully and wrote a small test program. Thats where I am right now.
You should be able to test the tool change in a sim.
03 May 2023 04:25 #270538
I might add that I have got TTS holders and all my tools are measured with lengths in the tool library so I can't wait to run a job with a manual pause for the tool changer.
04 May 2023 06:36 #270612
Basic Probe - Probe to surface:
I found the Bug!
QTdragon uses the Max XY Dist when probing to find the surface instead of Max Z Dist
In my case the XY Distance was fairly high and there was not enough Z axis travel so it threw an error. When I changed it to agree with my Max Z Dist it worked!
But where does the Z axis Probing Gcode come from?
I assumed it was from ~/linuxcnc/nc_files somewhere but it does not seem to be.
It would be great if you could push a fix for this Chris.
As an aside, the current probe routines are fairly inefficient and probably have their roots in Mach somewhere.
Linuxcnc can probe towards and away from a surface. This would be much more efficientWen I did this, the position change by about 0.02mm and under a glass, you could not even see a gap between the probe and the surface
But hey, I'll just settle for a working probe!
I found the Bug!
G91
F150 (fast)
G38.3 Z-10 probe 10mm)
F50 (slow)
G38.4 Z 10
G10 L20 P0 Z0
F150
G1 Z 10But hey, I'll just settle for a working probe!
04 May 2023 08:37 #270614
Looks like probing don doesn't use either distance, it uses max_travel:
From lib/python/qtvcp/widgets/probe_routines
# Straight down probing
# Probe Z Minus direction and set Z0 in current WCO
# End at Z_clearance above workpiece
def probe_down(self):
ACTION.CALL_MDI("G91")
c = "G38.2 Z-{} F{}".format(self.data_max_travel, self.data_search_vel)
if self.CALL_MDI_WAIT(c, 30) == -1: return -1
c = "G1 Z{} F{}".format(self.data_latch_return_dist, self.data_rapid_vel)
ACTION.CALL_MDI("G4 P0.5")
c = "G38.2 Z-{} F{}".format(1.2*self.data_latch_return_dist, self.data_probe_vel)
a = STATUS.get_probed_position_with_offsets()
self.status_z = float(a[2])
self.add_history('Straight Down ', "Z", 0, 0, 0, 0, 0, 0, 0, 0, a[2], 0, 0)
self.set_zero("Z")
if self.z_clearance_up() == -1: return
return 1
04 May 2023 08:42 #270615
manual tool change: are you saying the pop up dialog doesn't work in sims?
04 May 2023 09:52 #270620
Max_travel must be set from Max XY Dist in the probe panel. I could see this when running the ini with -d
I had it set to 50mm and the Z at 10mm. 50mm was too far for my Z so it was erroring. Eventually I twigged what was going on. Changing 50mm to 10mm fixed my problem.
The Z axis probing distance should be set by Z Max travel field.
I got this working today. Missing a connection and I found the answer heremanual tool change: are you saying the pop up dialog doesn't work in sims?
04 May 2023 10:26 #270624
Ok I can see the problem in the code.
The underlying probe routines don't even get separate xy/z max travel lengths.
It will take me a while to tease out the fix though.
04 May 2023 10:31 #270626
is there a big advantage of separate xy/z max lengths?
