Some of the machines i have built over time
- Topic Author
- Thank you received: 5926
26 Jun 2016 23:21 #76688
Some of the machines i have built over time was created by tommylight
Here is the link to my youtube channel with videos of some of the machines i have built over time, most of them running LinuxCnc.
Also featured are a KUKA KR150 robot i have installed, modified, wired and programmed for welding of oval tube steel fences, and some engravers that do nice pictures on stone, marble, granite, wood, glass, plastic or anything with a harder surface since they use a diamond bit at high speed.
www.youtube.com/channel/UCS0X88R7n7P2jIFwhIkw2Qw
Hope you enjoy,
Tom
Hope you enjoy,
Tom
The following user(s) said Thank You: Shu
05 Jul 2016 14:36 #77033
by Shu
Replied by Shu on topic Some of the machines i have built over time
Cool. Did you retrofit the Kuka robot with LinuxCNC?
- Topic Author
05 Jul 2016 19:18 #77046
1 That would have been to much work and i knew i was not getting paid for that amount of work.
2 It was in working order when we got it, and the original kuka teaching software is much easier to use for what we needed.
Regards,
Tom
Replied by tommylight on topic Some of the machines i have built over time
No i did not for 2 reasons :Cool. Did you retrofit the Kuka robot with LinuxCNC?
Regards,
Tom
- Topic Author
05 Jul 2016 19:22 #77047
I did retrofit this last week and it works nice, with initial height sensing and waiting for ARC OK signal before moving, etc.
forum.linuxcnc.org/forum/show-your-stuff...ter-with-ihs-and-ahc
Regards
Regards
- Topic Author
09 Jul 2016 18:34 #77231
Added the video of the above mentioned retrofit working fully automatic with initial height sensing and automatic height control. Did a design of a pegasus door, i will upload pictures later. It has a lot of short cuts and a lot of cutting in it, but it came up wonderfully and the machine preformed without a hitch.
Regards,
Tom
Regards,
Tom
- Topic Author
12 Jul 2016 00:54 #77325
Uploaded some pictures of the door on the latest video on youtube.
forum.linuxcnc.org/forum/show-your-stuff...th-ihs-and-ahc#77324
Regards,
Tom
Regards,
Tom
Time to create page: 0.177 seconds
