Retrofit of a plasma cutter with IHS and AHC
- Thank you received: 7504
01 Jul 2016 19:20 #76909
Retrofit of a plasma cutter with IHS and AHC was created by tommylight
This is the latest addition to the linuxcnc family, an old industrial plasma cutter with IHS and AHC.
Took about 4 days from start to finish, left most of original installation intact, removed the 2 servo drives and the big transformer used to supply power to drives, installed 2 gecko 320 servo drives and a big DC power supply, connected all the limit switches to the parallel port with needed modifications for adapting 24V signalling to 3.3V, left the E-stop and extreme limit switches intact ( all this will cut the power to the machine completely if things get out of hands ), made some more circuits for the "torch on" and "arc ok" signals, and added the hal component to wait for "arc ok" before moving.
Did some test cuts, and the results are awesome.
The actual plasma is a Hypertherm 3070 with original torch, water cooled of course. Need to attach the air cooler.
Compared to the original system with an unusable monitor, this is a joy to work on.
For anyone who might be wondering, everything is connected directly to parallel port with the added simple voltage dividers and a relay, a transistor (darlington) and some more resistors. Unfortunately i did not have mesa cards at hand, and getting them here is not easy, so i decided on this setup.
The owner was reluctant to do the retrofit, but now he is more than happy with the results and the ease of use, it took him about 4 hours to learn to use the machine.
Regards,
Tom
P.S. i am attaching the pictures at no particular order, they should be self explanatory.
Regards,
Tom
- BigJohnT
- Thank you received: 994
10 Jul 2016 17:09 #77268
by BigJohnT
Replied by BigJohnT on topic Retrofit of a plasma cutter with IHS and AHC
Sweet!
JT
JT
11 Jul 2016 19:28 - 11 Jul 2016 19:31 #77324
Replied by tommylight on topic Retrofit of a plasma cutter with IHS and AHC
Here are some pictures of a door design from the web.
Regards,
Tom
Regards,
Tom
Last edit: 11 Jul 2016 19:31 by tommylight. Reason: forgot the pictures
11 Jul 2016 19:56 #77326
There is a video of it being made on my youtube channel.
Tom
Tom
Time to create page: 0.481 seconds
