Servo drives costing 22 euros for 2 motors
- Thank you received: 7496
26 Oct 2016 23:57 #82125
Replied by tommylight on topic Servo drives costing 22 euros for 2 motors
That is nice, i just requested some samples, i have some uses for it regarding Linuxcnc! Thank you.
21 Mar 2017 23:54 #90038
By request, here are the config files for this example. Be aware that it uses a single parallel port in mode X, for 4 servo drives and 4 encoders so it has only 1 input left unused. Also in some cases the motors will run at will as they do not have enable inputs, if they go to an hard stop it will burn the mosfets or/and motor.
I case you do not need 4 drives, you may configure one of the outputs as enable out and wire another mosfet that will stop the power to the drives.
The following user(s) said Thank You: porshe, fungus
- porshe
08 Dec 2019 18:31 #152335
by porshe
Replied by porshe on topic Servo drives costing 22 euros for 2 motors
Hello. Can I connect this board via Pluto-P or MESA in servo driver mode?
08 Dec 2019 20:23 #152339
With Mesa yes, pluto i never used.Hello. Can I connect this board via Pluto-P or MESA in servo driver mode?
- billykid
- Thank you received: 83
09 Dec 2019 17:14 #152380
by billykid
Replied by billykid on topic Servo drives costing 22 euros for 2 motors
yes, pluto is a fpga, a boy used that one.
saluti
Mauro
saluti
Mauro
- porshe
11 Dec 2019 12:52 #152479
by porshe
On one site where they discussed this board, they wrote that you can make a current limit on the arduno. Apply ACS712 Sensor
11 Dec 2019 14:58 #152482
There are much cheaper and better alternatives now, like the 43A or the 30A ones for arduino, they look like they do have some type of feedback for current limiting or disabling the drives. I did order several of both types so i will test them when i get them and report back. At the price of 7 or 8 $ a piece, well worth investigating.
27 Dec 2019 23:18 #153340
Replied by andypugh on topic Servo drives costing 22 euros for 2 motors
Note that the chap who wrote the LinuxCNC Pluto driver says that he found then flaky and that they simply wouldn't work at all with some parallel ports.
I probably wouldn't recommend Pluto-P for new builds.
- billykid
28 Dec 2019 17:57 #153372
by billykid
yes, I also meant to use the pluto in case it already has one,
also because using a bare h bridge is better to have a faster servo thread, I used a PCI and managed to go to 8khz
with significantly better performance.
Mauro
Mauro
- Profed81
- Visitor
30 Aug 2020 01:32 #179992
by Profed81
Replied by Profed81 on topic Servo drives costing 22 euros for 2 motors
Why the fourth axis is linear? Do you have tested the fourth axis? I think it would be rotational axis
Time to create page: 0.721 seconds
