Rods "Spaceship" Scratch built Plasma Cutter build
- Thank you received: 5966
15 Oct 2020 12:51 #186196
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
I'll be back here in a week to see the poor machine in pieces !
Those accelerations will dismantle everything.
I did push mine to 68m/m with 10m/s/s acc and it just started ripping the belts clean. It worked for about 5 minutes and was fun to watch a 500Kg machine walk all over the shop, but it did not last !
- machinedude
- Thank you received: 273
16 Oct 2020 04:39 #186245
by machinedude
Replied by machinedude on topic Rods "Spaceship" Scratch built Plasma Cutter build
this was something I was thinking in the back of my head myself. with that much force on the acceleration it has to work hard on the connections. so finding a balance between crazy fast and not ripping things apart pushing things to hard is a fine line to define. i think the water sloshing around in the table is a good indicator to keep an eye on once things are down off the casters and on the ground starting off slow and working your way up to the brink might not be a bad idea it good to know you have the extra there if needed though
still fun to watch and impressive regardless
16 Oct 2020 05:18 #186247
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
Tommy and Dude, show a little faith guys.
You should know that spaceships don't run on rubber bands.
I was going to slow it down but I was told we did not get to the moon by going slow! So the spaceship has to do what the spaceship has to do....
Even if that is just to prove space travel is possible (without loosing a tile or an O ring!)
The following user(s) said Thank You: tommylight, pinder
- machinedude
16 Oct 2020 06:06 #186250
by machinedude
remember the Challenger Rod !!!
16 Oct 2020 06:14 #186251
Was that the tile or the O ring?remember the Challenger Rod !!!
- machinedude
16 Oct 2020 06:21 #186253
by machinedude
i don't remember honestly. i just watched to burst into flames as a kid. so don't push your spaceship to hard
16 Oct 2020 06:25 #186255
O ring.
16 Oct 2020 07:39 - 16 Oct 2020 07:40 #186259
Gee, the were just getting to the moon when I was a kid
Wasn't it a rubber part that failed on your table too Tommy?O ring.
Last edit: 16 Oct 2020 07:40 by rodw.
16 Oct 2020 09:34 #186268
Yup.Gee, the were just getting to the moon when I was a kid
24 Oct 2020 22:53 #187148
So I am pleased to say after about 4 years in the making, I finally have the spaceship in a final position and off its casters. We also routed all the air and power down from overhead so there is nothing on the ground to trip over.
We gave it another torture test while cutting on Friday and the boost feature has solved the motors eventually overheating and the motors are much cooler to the touch. But I had an over temperature fault on the top most driver in the control panel. I think it is my fault for placing the drives where the old ones were which meant that drive was being heated by the ones below it which is not per the layout in the Lam manual. More adjustments!
But I had wired the Lam driver fault output to joint.L.amp-fault-in. This basically triggered an estop event and therefore I was unable to recover and continue to cut the file in a complex nest.
Is there an alternative method I could use to halt motion yet still recover?
The following user(s) said Thank You: pinder
Time to create page: 0.200 seconds
