Rods "Spaceship" Scratch built Plasma Cutter build
- Thank you received: 5934
11 Oct 2022 12:10 #253960
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
Yeah, those i can find here, in a box, useless assortment of single, dual, and a single set of 4 pin, for 48 Euros!
About 6 or 7 connectors in total.
Not getting those for now.
11 Oct 2022 20:27 #253979
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
I don't think I've ever had to disconnect a motor cable at the control box. You just need to be able to disconnect the motor to service itI second the cable gland Idea not very convenient if you have to disconnect things but if you need IP68 then they are great. Best bang for the buck.
12 Oct 2022 09:23 #254010
by MontStar
Replied by MontStar on topic Rods "Spaceship" Scratch built Plasma Cutter build
I was thinking Deutsch connectors at the motor end. You can get different keys for them, use A key for motor drive, B key for encoder. With the bulkhead mount, no cables just flopping about.
I'm planning my table at the moment, 2.5m x 4m. I've done most of the design work for the table, working on the wiring schematic now.
The following user(s) said Thank You: rodw, my1987toyota
15 Oct 2022 13:25 #254168
by arvidb
Replied by arvidb on topic Rods "Spaceship" Scratch built Plasma Cutter build
Deutsch looks nice but as Rod says, about €400+VAT for the crimp tool... well, it's better than Amphenol crimp tools I guess!
Speaking about Amphenol, these look pretty nice: sensor|mate CM12: M12S-04BMMB-SL7002 (male), M12S-04BFFB-SL7002 (female). Data sheet at www.amphenol-industrial.de/en/Downloads -> Circular Connectors -> sensor|mate product catalogue.
* 630 VAC
* 12 A
* Screw connection to leads
* Total size for cable-to-cable connection: about D20 mm x 110 mm
* About €11 + VAT per connector
(The female connector is currently out of stock at both TME and Mouser. Expected delivery in a month from Mouser though.)
Note I haven't used these myself!
* 630 VAC
* 12 A
16 Oct 2022 11:30 #254215
by MontStar
the amphenol connector is interesting. I'll agree €400+VAT is a bit steep for the Deutsch tool, but I've just purchased the one in my previous post for around AU$62. And the inline cat spec connector kit is around AU$20. There are cheaper ones, but the CAT spec connectors are a better connector than the standard Deutsch connector
24 Jan 2023 11:03 #262807
Well its official. The spaceship plasma is going to a new home. The new owner is Jason who decided to ditch his Torchmate in favour of the Spaeship! That surely says how good Phil's QTplasmac is.
My Thermal Dynamics machine died some time ago and required over AUD $5k in parts. I thought about replacing it but in reality I have not been doing any adhoc or prototyping work for a long time. Its been much easier to outsource my parts to a lasr cutter so I don't have any cleanup! This is a pre\actice I adopted some time before the plasma cutter failed.
So Jason will be putting on another plasma cutter on it to bring the spaceship
It has been a lot of fun building this and the features Phil and Snowgoer and all the other contributors have added to QTplasmac has set up a machine that has an amazing feature set. So for me the fun is in building the machine so its time to do something else!
The following user(s) said Thank You: phillc54, snowgoer540
24 Jan 2023 11:07 #262809
by phillc54
Replied by phillc54 on topic Rods "Spaceship" Scratch built Plasma Cutter build
I think that you need to build a fibre laser cutter now.
The following user(s) said Thank You: rodw, snowgoer540
24 Jan 2023 11:43 #262810
I'd like to do more with ethercat drives. I'd like to do custom homing for cia402 drives and Dewey has done a lot of work with the code since my last try so I think it would be pretty easy now!
Just imagine 220v AC drives homing to absolute encoders and ethercat IO module up with the torch! There would be almost no wiring!
Don't tempt me! I have a mesa control panel with lam drives here fully built too! Maybe a dainty plasma like yours is in order.I think that you need to build a fibre laser cutter now.
14 Aug 2023 01:39 #277899
by frankjr1
Replied by frankjr1 on topic Rods "Spaceship" Scratch built Plasma Cutter build
I like this build. Would like parts list and plans associated with it.
Time to create page: 0.192 seconds
