Convert Fusion360 Tool Library to LinuxCNC Tool Table
- ntc490
- Thank you received: 6
06 Jan 2017 06:49 #85326
by ntc490
Convert Fusion360 Tool Library to LinuxCNC Tool Table was created by ntc490
Not sure if this is the right place to put this, but I recently wrote a Python script that creates a LinuxCNC Tool Table based off your Fusion360 Tool Library. You just export your Library from Fusion360 and run this script on it to generate your new Tool Table. Hopefully it helps someone else. github.com/ntc490/fusion360/
The following user(s) said Thank You: andypugh, Jake, racedirector, plopes9000, harindugamlath, ucancallmebob89
- Thank you received: 4640
06 Jan 2017 11:06 #85331
Replied by andypugh on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
Could be handy, indeed.
I sometimes find myself wanting to go the other way, clear out all the stuff in Fusion that I don't have and show only my actual tools with the right numbers.
- racedirector
- Thank you received: 42
06 Jan 2017 12:47 #85334
by racedirector
Replied by racedirector on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
Awesome, thanks NTC!
- CrashCNC
24 Nov 2017 19:26 - 24 Nov 2017 19:28 #102309
by CrashCNC
Replied by CrashCNC on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
This script seems to be awesome.
I'm a noob to linux.
I understand how to run python code, but do not understand "run this script on it". Can you elaborate or point me to a link for reading up on the topic?
I seem to be getting a message that is:
"import error: no module named docopt"
I am running the install of linux that comes packaged with LinuxCNC 2.7
Last edit: 24 Nov 2017 19:28 by CrashCNC.
24 Nov 2017 19:41 #102313
docopt seems to be a library for parsing command-line arguments.
If you go to Settings->Synaptic Package Manager and search for "docopt" you will find python-docopt. That should fix the problem.
Or you could alter the script to use sys and sys.argv. Or, on fact, for a one-off, just edit the script to hard-coded values.
- Jake
- Thank you received: 10
25 Nov 2017 12:23 #102333
by Jake
Replied by Jake on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
This could be handy Thanks!
- plopes9000
- Thank you received: 18
15 Mar 2021 15:02 #202354
by plopes9000
Replied by plopes9000 on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
I too found this script needed and very useful - thank you Nathan.
While I do not wish to add tools manually in LinuxCNC to bring over to fusion 360, I do not wish to get measured tool offsets overriden when I change the fusion library and run the script to update the LinuxCNC tool file. Hence in my view of the workflow, fusion 360 tool library is the master tool library but measured tool offsets should be retained.
Another thing that I came to need, was to take advantage of the fusion 360 library details on tool holder length, tool length and tool type, to extract hints for tool setter tool measurements.
I ended up creating a v2 of the script and made a pull request on Nathan GitHub rep github.com/ntc490/fusion360/pulls.
Unfortunately adding information like that to the LinuxCNC tool table it is not a simple matter. I thought of using the description field or use columns not needed for a mill. I went with the latter, and so it is not a general solution.
None the less I thought it may be useful for someone else, hence sharing it here.
17 Mar 2021 13:45 #202597
There are ways to use a real database or an alternative data structure for the tool table in LinuxCNC Master (ie, the dev version)
linuxcnc.org/docs/devel/html/tooldatabase/tooldatabase.html
- egemens
- Visitor
24 Mar 2024 16:24 - 24 Mar 2024 16:32 #296627
by egemens
Replied by egemens on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
Hello,
I changed the script a little bit to be run inside Fusion 360 as an add-in.
It asks you to choose a json file from CAMTools directory and outputs a formatted file using ntc490's code above. Previously i made a similar one for Mach 3, used the same approach with LinuxCNC. Only tested on a mac. Hope it is useful.
github.com/egemens/Fusion-360-tools-to-LinuxCNC-exporter
Last edit: 24 Mar 2024 16:32 by egemens.
- Ritterchen
17 Jun 2024 08:38 #303158
by Ritterchen
Replied by Ritterchen on topic Convert Fusion360 Tool Library to LinuxCNC Tool Table
Hi ntc490 and egemens,
thanks a lot for these scripts, here is the version that works with windows. My first python script (change) so handle with care!
Reads the local tool library and exports it to the Desktop.
Make sure to convert your cloud library into a local one before, if you only run it on the cloud.
Don't have a fancy github, so here it is - feel free to host it together with the other one or adjust to handle Windows too
The following user(s) said Thank You: egemens
Time to create page: 0.137 seconds
