Harmonic drive 4th axis build
09 Nov 2018 06:51 #120313
by Hakan
Replied by Hakan on topic Harmonic drive 4th axis build
13 Nov 2018 09:28 #120529
by Hakan
The plates were not very flat, so facing them with the fly cutter and start the final assembly.
16 Nov 2018 10:25 #120824
by Hakan
Continue with the final assembly and start by dealing with a stuck tapered pin.
18 Nov 2018 16:03 #120951
by Hakan
Making surfaces parallel to the harmonic drive.
20 Nov 2018 07:53 #121044
by Hakan
Working on the top cover.
22 Nov 2018 23:37 #121246
by Hakan
Finally starting to use it. If you haven't followed this series, the last five minutes may be worthwhile watching anyway.
23 Nov 2018 06:58 #121249
by JC10
Andy, I might be interested in your remaining casting for a FHA-25. I have a few questions. I sent you a PM on CNCZone.
Replied by JC10 on topic Harmonic drive 4th axis build
Do you want one of these castings?
bodgesoc.blogspot.com/2017/05/harmonic.html
I think I have one left.
25 Nov 2018 19:29 - 29 Nov 2018 07:11 #121335
by Hakan
Yes, worthwhile checking alternatives to build from steel plates, it is a lot of work...
I thought I was ready with the rotary axis, but there was some work needed in Fusion 360 to get the rotary axis well supported. As usual, I made a video about that.
The fixed Fusion 360 post processor for my A axis and inverse time feed mode is attached. For linuxcnc of course. You can see it in action in the video. The G-code runs directly, without any hand-editing or such things.
History:
25 November 2018: The version in the video
28 November 2018: Changed tcp on line 585 to false. Affected paths at tool position angle <> 0
29 November 2018: Added G94 to canned cycles
Here is a shared link to the Fusion 360 model of the harmonic drive housing being built in this video series: a360.co/2r4Xv3s
Due to the rework needed, it is not in the best conditions. If you use it, you better check that all dimensions are what you need.
History:
Last edit: 29 Nov 2018 07:11 by Hakan.
The following user(s) said Thank You: JC10
02 Sep 2019 19:28 #143926
by opw
If you still have one, I'd be interested...
Replied by opw on topic Harmonic drive 4th axis build
02 Sep 2019 20:13 #143930
Where are you? The casting is in the UK.
Replied by andypugh on topic Harmonic drive 4th axis build
Time to create page: 0.178 seconds
