My Grizzly G0602 Lathe
- my1987toyota
- Topic Author
- Thank you received: 280
08 Oct 2020 00:15 #185317
by my1987toyota
Replied by my1987toyota on topic My Grizzly G0602 Lathe
Looks good AlekseySP . What kind of accuracy can your lathe hold?
09 Oct 2020 00:12 #185410
by AlekseySP
But don't expect a miracle, you will have to figure out what machine can do and what can't. Removing a compound slide improves rigidity. If you want to use simple steppers 1.8 deg 200 steps per rev, keep in mind their downsides: first, they are slow. In the beginning it might be a not a bad thing but after a while it's getting annoying. Faster they spin more chance to lose steps. And don't forget about acceleration, it's a very important parameter. Second problem of stepper is a resolution: 200 pulses per rev with 5mm pitch ballscrew gives you approximately 0.001in increment. Setting microstep helps during motion, but motor can't stop between full steps. Again, for most hobby projects it's enough. Plus nothing can beat a price.
Replied by AlekseySP on topic My Grizzly G0602 Lathe
It's hard to say, we have only cheap iGage scale on Z, so we didn't measure accuracy in all working space. But repeatability is very good, within few tenths. First i had some problems, but after tuning servos everything was fine.Looks good AlekseySP . What kind of accuracy can your lathe hold?
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
10 Oct 2020 20:58 #185630
by my1987toyota
thanks AlexseySP I will defiantly keep that in mind during the build.
- my1987toyota
- Topic Author
13 Oct 2020 01:26 #185902
by my1987toyota
Well I did it. The lathe has been ordered just moments ago . I decided to still go with the G0602Z with
the already installed DRO instead of sourcing the linear scales and installing them myself. I cant wait to
dig into this machine and CNC it.
13 Oct 2020 06:11 - 13 Oct 2020 06:16 #185921
by MalteS
Replied by MalteS on topic My Grizzly G0602 Lathe
1) I converted my Lathe two years back. I have two encoders for X/Z to use it manually. I'd strongly recommend this.
2) I do have Glasscales and think this is a waste of money. I did this to measure tolerances / fits in X, but you never measure really what happens on the part.
3) open loop steppers work fine. You want to use a belt reduction on X to get resolution. I think I get 0.002mm resolution in X and 1m/min travel.
4) I used a normal spindle in X for space reasons. Ballscrews are imho not essential on a lathe
5) I used Machinekit + Beaglebone Black and IO over PRU. Main reason are that I needed lots of IO
Mesa Cards are an option and I would consider this
6) since this is the show your stuff forum.... Video here. Enable the English subtitles
Last edit: 13 Oct 2020 06:16 by MalteS.
13 Oct 2020 06:14 - 13 Oct 2020 06:15 #185922
by MalteS
Del
Last edit: 13 Oct 2020 06:15 by MalteS. Reason: Del
- my1987toyota
- Topic Author
13 Oct 2020 21:12 #186022
by my1987toyota
thanks Malte S ,I may have to try the dual MPG wheels on my build. I was just going to do a single with a selector switch
but now the dual wheels look extremely handy to have . The biggest problem I had with going to glass scales
on a machine like the one I am getting is how much space the X axis glass scale would require over the magnetic one.
- my1987toyota
- Topic Author
14 Oct 2020 22:21 - 14 Oct 2020 22:59 #186134
by my1987toyota
another quick update . The ballscrew kit and steppers have been ordered
ballscrew kit
stepper motors
A few steps closer.
I do have a question for those who have built cnc lathes .
Is it better to drill with the tail stock drill chuck or set up a drill chuck for the quick change tool post ?
and What rotary encoder is recommended for the spindle ?
ballscrew kit
stepper motors
A few steps closer.
Last edit: 14 Oct 2020 22:59 by my1987toyota.
15 Oct 2020 07:40 - 15 Oct 2020 07:41 #186158
by MalteS
I have both drilling options but almost exclusively use the tailstock. But I think that depends on the use case. If you make the same part all the time and that involves driĺing you want a turrent (i dont have one) and the ability to drill
I used printed parts and sensors as encoder. But setting this up to have the right distance was a pain. A pic is here:
forum.zerspanungsbude.net/viewtopic.php?...394&start=10#p453365
Last edit: 15 Oct 2020 07:41 by MalteS.
- my1987toyota
- Topic Author
15 Oct 2020 11:09 #186183
by my1987toyota
thank you MalteS. unfortunately I cant read German. That said the pictures were very informative.
I am trying to figure out if I should go that route or use one of the Omron rotary encoders with a drive belt
off the spindle
off the spindle
Time to create page: 0.206 seconds
