Homemade, cheap, plasma CNC
- snowgoer540
- Thank you received: 754
10 Mar 2022 19:21 #236880
by snowgoer540
Replied by snowgoer540 on topic Homemade, cheap, plasma CNC
FWIW, this g-code file ran fine on my sim machine (imperial machine though), but without a backup of your config, it's impossible to simulate your machine.
To get a backup of your config, click "BACKUP CONFIG" in the parameters (or settings if your screen is 4:3) tab. Upload the resulting file here.
The following user(s) said Thank You: RNJFAB
11 Mar 2022 23:28 #236966
by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
12 Mar 2022 00:01 #236967
by phillc54
Replied by phillc54 on topic Homemade, cheap, plasma CNC
I do see the message in your logfiles.
I made a sim of your config and the file runs without issue.
If you jog your Z axis until it gets to the bottom of travel, how far in mm is that below the top of the slats?
12 Mar 2022 02:37 - 12 Mar 2022 02:39 #236976
by RNJFAB
5mm
I did some more cutting today, the error pops up when the first cut starts.
also took a short video but can upload it yet.
Last edit: 12 Mar 2022 02:39 by RNJFAB.
12 Mar 2022 06:07 #236979
by phillc54
I have done a heap of testing and cannot work it out. With the config as you posted, with the safe height at 99mm I only see the warning if the material is around 61mm higher than the top of the slats.
In the most recent post you mention the first cut, does it only happen after the first probe?
- Thank you received: 5997
12 Mar 2022 13:44 #236995
Replied by tommylight on topic Homemade, cheap, plasma CNC
Check for active offsets, there is a small green ball shape if there are any.
12 Mar 2022 20:46 #237019
by RNJFAB
Thank Phil,
the error pops up on the first cut for each piece.
it will only move up 8.4mm above the surface for movements.
i have tried some older cut files and it for the same thing making me think that I have changed something in linux.
thanks tommy,
heading to the shed no to check that.
thanks tommy,
12 Mar 2022 22:26 #237032
by RNJFAB
No green ball Tommy.
12 Mar 2022 22:38 #237037
by phillc54
Man, this is strange... Sorry for the pile of questions but I can't really get my head around what is happening.
When you say 8.4mm do you mean when it is moving between cuts?
What is the Safe Height parameter when it does this?
Does changing the Safe Height parameter change thie 8.4mm to something else?
If you do Z axis MDI of say 20mm does it actually move 20mm?
If you set the Safe Height parameter to a low value like 20mm does it still give the warning?
12 Mar 2022 22:49 #237040
Did you zoom in on the 0,0,0 coordinates? It is small, very small.
Also i did check on one of my machines today while i was chasing a gremlin in the electronics, PlasmaC and QtPlasmaC will always have that green ball on all machines with limit switches and proper homing... soooo
Check the G code quick reference for offsets and cancel all of them, there are at least 2, maybe more, then do the "torch just under the slats" exercise again and touch off Z.
I am blindly hoping there is a tool offset active messing things up, otherwise i am out of ideas ... or am i ???
Can you upload a video on youtube with the normal use process, from start to ... when things mess up.
My dog has one ... oh that ball !No green ball Tommy.
Time to create page: 0.164 seconds
