Homemade, cheap, plasma CNC
- Thank you received: 5993
13 Mar 2022 01:36 #237061
Replied by tommylight on topic Homemade, cheap, plasma CNC
From the video, the safe height is still lower than probe height.
From the missing green ball thingy, you have not touched off the torch/Z.
Do the buttons 1, 3, 4, 9, 10, work as expected?
13 Mar 2022 01:38 #237062
by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Thanks Phil,
Working as per normal.
Knew it was something missing.
13 Mar 2022 01:39 #237063
by RNJFAB
Do the buttons 1, 3, 4, 9, 10, work as expected? Yes
13 Mar 2022 01:47 #237067
by phillc54
Glad it is going again.
That was probably my fault, I made a change on 18 Jan and missed that net line. I fixed it a couple of days later but the Buildbot may not have updated for a while so there would have been a window during which any updates would lose that net line.
The intereting thing is that the error you got it not what I would have expected.
Replied by phillc54 on topic Homemade, cheap, plasma CNC
Thanks Phil,
The following user(s) said Thank You: tommylight, RNJFAB
13 Mar 2022 01:51 #237068
Wait, is it working now?
I was still thinking what else could cause such behavior, so can i go to sleep now? 3AM ... eternal.... <<<what song was this from?
The following user(s) said Thank You: RNJFAB
13 Mar 2022 03:15 #237074
by RNJFAB
thanks Phill and Tommy,
Another problem solved.
I also found a line in the hal file that was out of place, so I fixed it too.
#*******************net plasmac:laser-switch <= qtplasmac.laser_on
# Tandem AXIS Y2 JOINT 2
13 Mar 2022 04:13 #237076
Still up .... 5:12AM
Need sleep .... scratch that, need brain !
13 Mar 2022 04:14 #237077
by phillc54
Haha, if you find a spare one can I have it.Still up .... 5:12AM
13 Mar 2022 08:24 #237083
by RNJFAB
I'll have one too.
16 Apr 2022 08:38 #240382
by RNJFAB
ohmic sensoring coming soon. doing it a little differently to most by using a THCAD10 (Not the traditional THCAD5).
Hopefully in a few weeks it will be up and running
Time to create page: 0.270 seconds
