ANother QTPlasmac machine
23 Oct 2021 18:30 #224012
by bevins
ANother QTPlasmac machine was created by bevins
Did another QTPlasmac machine. It is working decent now with sheetcam QTPlasmac, 7i92-7i76, thcad, ohmic probing and some steppers.
Running a Lincoln ProCut-55.
Cant get the mpg working but I think the encoder is bad. Going tp swap out tomorrow with a known good one.
23 Oct 2021 18:41 #224013
Replied by rodw on topic ANother QTPlasmac machine
Good work. How does the downdraft work for you? Is it enough just at one end?
What were you showing after the controlbox at the end of your video?
23 Oct 2021 18:56 #224015
by bevins
Replied by bevins on topic ANother QTPlasmac machine
The downdraft is working insane. There no smoke anywhere.IT pulls everything. The blue box is the unit that got the suction and filters in it. Two different type of filters. Works amazing.Good work. How does the downdraft work for you? Is it enough just at one end?
23 Oct 2021 18:59 - 23 Oct 2021 19:00 #224016
by bevins
Thanks for your help Rod and work, thanks Tommy for his constant relentless help and thanks to Phil and snowy for their work on QTPlasmaC. It is quite amazing.
Last edit: 23 Oct 2021 19:00 by bevins.
23 Oct 2021 19:03 #224017
Your are welcome. Who knows, one day I might want to make a router and you can return the favour!
I would be interested to know some details on the extraction unit.
23 Oct 2021 19:07 #224018
by bevins
Sure I'll send you some info tomorrow on the extraction unit when I get to the shop.
- Thank you received: 5983
23 Oct 2021 23:49 #224045
You are welcomed, always.
Replied by tommylight on topic ANother QTPlasmac machine
Ummm ... what did i do now???Thanks for your help Rod and work, thanks Tommy for his constant relentless help and thanks to Phil and snowy for their work on QTPlasmaC. It is quite amazing.
Time to create page: 0.338 seconds
