Promecor Lathe retrofit with TKXHMI
- fsabbatini
- Thank you received: 49
06 May 2022 23:42 #242183
by fsabbatini
Promecor Lathe retrofit with TKXHMI was created by fsabbatini
Just las lathe retrofit I did!
- Thank you received: 5946
06 May 2022 23:48 #242184
Replied by tommylight on topic Promecor Lathe retrofit with TKXHMI
Where? How? What?
- fsabbatini
06 May 2022 23:50 #242185
by fsabbatini
Replied by fsabbatini on topic Promecor Lathe retrofit with TKXHMI
Hahaha I guess the link didn’t went through, here it goes again
06 May 2022 23:56 #242186
Very nice, thank you.
Video 2 not working for me.
09 May 2022 04:42 #242351
by Becksvill
Replied by Becksvill on topic Promecor Lathe retrofit with TKXHMI
Love it!
What framework are you using?
And have you got tool wear offsets working well?
Regards
Andrew
Regards
Andrew
09 May 2022 06:22 #242359
by silopolis
Replied by silopolis on topic Promecor Lathe retrofit with TKXHMI
Hey !
Very happy to see this post (thanks Andrew for pointing us there on the mailing list :+1: ) !
You know from YT comments that at least Phil and I are big fans of $inumerik UI and features, so you won't be surprised we hope to know anything and everything of this gorgeous implementation
Congratulations anyway for this and thanks for showcasing this build.
TY
TY
10 May 2022 13:22 #242488
by tome
-Tom
Replied by tome on topic Promecor Lathe retrofit with TKXHMI
Add me to that list! Is this user interface available? Also, what is the interface hardware, that doesn’t look original to the machine?Hey !
TY
-Tom
10 May 2022 16:57 #242504
Title fixed from "larhe" to "lathe".
- fsabbatini
15 May 2022 18:57 #243040
by fsabbatini
Thanks all for your replies!
I have been working for about one and a half years on this. Some history first:
We are a company localized in Argentina, we have been building special machines for several industria for 25 years and always using Fanuc/Siemens on our machines. This country government has many restrictions on imported goods (because lack of dollars, populism and issues we can argue all day long) so I started working on making Linuxcnc more professional , and what I got so far is this:
-proper single block working
-industrial tool manager with life manager by part count or by cutting time. Tools offsets and tool wears. Tool manager working as $inumerik , meaning you can have t3d1 for example and also t3d2 , you can have as many edges for a tool as you want.
-kind or R parameters (using variables) but showed on the screen.
-MDI working as $inumerik or Fanuc, you can put several commands in same file
-currently executing line showing exactly as it should be! Even in subroutines (for gosh sake!!!)
-interface for touch screen, mouse not required any more
-editor able to open file while machine working
-several editors opening at same time
-usb handled right on the hmi, no need to go to desktop to copy files
-PLC alarms bits (%Axx) to show alarms at hmi, distinguishes between messages and alarms
-offsets now have “fine” correction
-(POPUP, “example”) shows popup on hmi for operator information
-ethercat drive homing implemented into homing.c
-m66 can wait forever
-m functions gives output to PLC (if configured) and plc must acknowledge it
And many more I am not remembering right now.. if you like I can post more videos of all these features
Sorry my misstyping , doing this from the phone!
Regards
Franco!
Regards
Franco!
15 May 2022 19:18 #243043
Replied by cmorley on topic Promecor Lathe retrofit with TKXHMI
Will you release the code changes to linuxcnc?
