Promecor Lathe retrofit with TKXHMI
- fsabbatini
- Thank you received: 49
25 Jul 2022 11:57 #248245
by fsabbatini
Replied by fsabbatini on topic Promecor Lathe retrofit with TKXHMI
Hi Spumco, thats the reason i started the development of this lcnc enhancements, there are tons of machines with cnc/electronic problems and i wanted to get a good replacements of it without loosing features.
I need more time to finish 3d plotting and 3d simulation and then i will publish it with some scheme of donations so we (my team and I) can keep up the development.
The new futures we are working on:
- Multi channel (siemens name) / Multi path (fanuc name) with all that implies (synch singals across channels, assigning spindle to channel, etc.)
- 3d simulation (backplot is a different thing, remember backplot have issues with infinite looping or loops with high number increments)
- 3d quick preview (with the issues mentioned before)
- S-Curve path interpolator
- Ability to change between S-Curve and constant accel on the fly (there are some process that constant accel is better, for example threading, as you need to copy-as-close-as-you-can the spindle variations)
Best regards and patience please
Franco
Franco
25 Jul 2022 15:43 #248264
by spumco
Replied by spumco on topic Promecor Lathe retrofit with TKXHMI
Thanks for the response - much as I expected.
You publish and let us know where to donate, and I'll chip in.
Time to create page: 0.124 seconds
