Encoder signals to BBB
07 May 2024 13:47 #300036
by keryboros
Encoder signals to BBB was created by keryboros
Hello
I have made my DIY CNC milling machine with BeagleBone Black (Machinekit) and DIY cape. I used ARM.BeagleBone.Xylotex setup as base and modified that to work with my machine.
I used old Omron servo drivers and motors with DIR and STEP signals. It kinda works but now I'd like to add feedback signals from servos to BBB (2048 pls/rev).
So there is quadrature signals from X, Y and Z. I'm planning to use these pins P9:25, P9:27, P9:28, P9:29, P9:30, P9:31
I have understood that these pins are in PRU0 and first I have to config the those as "pruin" in setup.sh file?
Then the ini-file now:
[PRUCONF]
DRIVER=hal_pru_generic
CONFIG=pru=1 num_stepgens=3
PRUBIN=xenomai/pru_generic.bin
so can I change it to:
CONFIG=pru=0 num_stepgens=3 num_encoders=3
And how to I do the HAL wiring?
Here is the pins that are in use now:
P8.07 out # gpio2.2 Enable System
P8.10 in # gpio2.4 XLIM
P8.11 out # gpio1.13 X_Dir
P8.12 out # gpio1.12 X_Step
P8.13 out # gpio0.23 PWM0/SPINDLE
P8.14 in # gpio0.26 YLIM
P8.15 out # gpio1.15 Y_Dir
P8.16 out # gpio1.14 Y_Step
P8.18 in # gpio2.1 ZLIM
P9.15 out # gpio1.16 Z_Step
P9.23 out # gpio1.17 Z_Dir
P8.09 in # gpio2.5 STOPin
Are these step/dir signals used by PRU 1? Or can I use these with PRU 0?
[PRUCONF]
- Thank you received: 5983
11 May 2024 19:25 #300396
Replied by tommylight on topic Encoder signals to BBB
Might want to try the MachineKit forums, they use BBB, we do not, although MachineKit is a fork of LinuxCNC.
11 May 2024 21:49 #300406
Replied by PCW on topic Encoder signals to BBB
Unfortunately, the Machinekit forum seems dead (tumble weeds and all)
A lot of great code infrastructure that would have improved LinuxCNC seems lost
11 May 2024 22:07 #300408
Still on github, hal section had an update 2 months ago, cnc section 4 years ago.
github.com/machinekit/machinekit
What was/is so good? Have not messed with it in more than 10 years...
12 May 2024 01:14 #300416
by cornholio
Replied by cornholio on topic Encoder signals to BBB
The mailing list is still active, not very, but if some one asks a question there are replies.
Found some info buried at home
Time to create page: 0.321 seconds
