I have a stepgen running in velocity mode from a hypot component that would be handy to be able to jog it while my machine is paused. The part I need to move is run by a servo through a belt drive and I can disable the drive and reach in the machine to grab the pulley and move it but it is a bit of a chore depending on where the gantry is. One options I can think of are to have a separate stepgen hooked up to the same pins that I could control when paused by a switch or keyboard but I don't think that would work while paused. Another option would be to hook up a cheap signal generator in parallel from the BOB to the servo drive to feed it steps while LinuxCNC is paused but that sounds like a good way to damage the drive. Can LinuxCNC stop in mid-step where the breakout board may, or may not be sending a step signal to the servo drive?
Thanks, Badger
