The 7i96s is running the firmware it came with - I'm struggling to find if I can pull the specific firmware name from the card, but this is the dump from mesaflash:
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: OutM
There are 1 of OutM in configuration
Version: 0
Registers: 1
BaseAddress: B000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InM
There are 1 of InM in configuration
Version: 0
Registers: 5
BaseAddress: 8500
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I96_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-1 0 IOPort InM 0 Input0 (In)
TB3-2 1 IOPort InM 0 Input1 (In)
TB3-3 2 IOPort InM 0 Input2 (In)
TB3-4 3 IOPort InM 0 Input3 (In)
TB3-5 4 IOPort InM 0 Input4 (In)
TB3-6 5 IOPort InM 0 Input5 (In)
TB3-7 6 IOPort InM 0 Input6 (In)
TB3-8 7 IOPort InM 0 Input7 (In)
TB3-9 8 IOPort InM 0 Input8 (In)
TB3-10 9 IOPort InM 0 Input9 (In)
TB3-11 10 IOPort InM 0 Input10 (In)
TB3-13,14 11 IOPort SSR 0 Out-00 (Out)
TB3-15,16 12 IOPort SSR 0 Out-01 (Out)
TB3-17,18 13 IOPort SSR 0 Out-02 (Out)
TB3-19,20 14 IOPort SSR 0 Out-03 (Out)
TB3-21,22 15 IOPort OutM 0 Output4 (Out)
TB3-23,24 16 IOPort OutM 0 Output5 (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3 17 IOPort StepGen 0 Step/Table1 (Out)
TB1-4,5 18 IOPort StepGen 0 Dir/Table2 (Out)
TB1-8,9 19 IOPort StepGen 1 Step/Table1 (Out)
TB1-10,11 20 IOPort StepGen 1 Dir/Table2 (Out)
TB1-14,15 21 IOPort StepGen 2 Step/Table1 (Out)
TB1-16,17 22 IOPort StepGen 2 Dir/Table2 (Out)
TB1-20,21 23 IOPort StepGen 3 Step/Table1 (Out)
TB1-22,23 24 IOPort StepGen 3 Dir/Table2 (Out)
TB2-2,3 25 IOPort StepGen 4 Step/Table1 (Out)
TB2-4,5 26 IOPort StepGen 4 Dir/Table2 (Out)
TB2-7,8 27 IOPort QCount 0 Quad-A (In)
TB2-10,11 28 IOPort QCount 0 Quad-B (In)
TB2-13,14 29 IOPort QCount 0 Quad-IDX (In)
TB2-16,17 30 IOPort SSerial 0 RXData0 (In)
TB2-18,19 31 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 32 IOPort SSerial 0 TXEn0 (Out)
Internal 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01 34 IOPort None
P1-02/DB25-14 35 IOPort None
P1-03/DB25-02 36 IOPort None
P1-04/DB25-15 37 IOPort None
P1-05/DB25-03 38 IOPort None
P1-06/DB25-16 39 IOPort None
P1-07/DB25-04 40 IOPort None
P1-08/DB25-17 41 IOPort None
P1-09/DB25-05 42 IOPort None
P1-11/DB25-06 43 IOPort None
P1-13/DB25-07 44 IOPort None
P1-15/DB25-08 45 IOPort None
P1-17/DB25-09 46 IOPort None
P1-19/DB25-10 47 IOPort None
P1-21/DB25-11 48 IOPort None
P1-23/DB25-12 49 IOPort None
P1-25/DB25-13 50 IOPort None
A 7i84 would be lovely, but I would need to buy it with some other hardware to get over the current landed import cost to the UK. I will get one at some stage, and probably make a more featured MCP.
