Unwinding Rotary Axis for Homing
1 year 3 months ago - 1 year 3 months ago #332459 by jschulze
Hi All,
Just working on finishing up a 5/6 axis router build and I'm trying to wrap my head around homing the C axis on the head.  I'm aiming to have 720deg of rotation, maybe more.  What I'd like to do is automatically unwind the head during homing, so I don't wind up the cables over time.  So the controller would store the last position (it's really difficult to back drive so I'm not worried about it moving much while the machine is off),  then move in the the correct direction to get back to 0deg (not just the shortest way) and then start the homing process using a switch and encoder index pulse ,this part is no problem.  I had a few ideas on how to accomplish this, but I was wondering if there's some easy solution I'm overlooking.
Last edit: 1 year 3 months ago by jschulze.
The following user(s) said Thank You: besriworld, COFHAL
1 year 3 months ago #332460 by COFHAL
Your project is very interesting. Where did you get the spindle mount?
1 year 3 months ago #332489 by jschulze
The spindle mount is just something I came up with and made.  Right now it fits a cheap air cooled 80mm 2.2kw spindle, but I can fit a 100mm diameter spindle if I need to.  I machined a hole in the side of the spindle to feed the wiring out of and through the center of the side bearing.  I hope that will save me from tangling up the wiring.
The following user(s) said Thank You: COFHAL
1 year 3 months ago #332504 by COFHAL
Could you share your 3D CAD model? If not, it's not a problem.
1 year 3 months ago #332510 by tommy
It might be better to use an absolute encoder on the C axis in your case. I also have a 5-axis head/head design with ±185° of rotation, and the unwinding is handled by the postprocessor in CAM.
Looking at your design, did you integrate harmonic drives on these two rotary axes?
1 year 3 months ago #332538 by jschulze
Here's the file for the head assembly. It's a fusion archive, so hopefully it included all the components properly. If you want a different format just let me know.
drive.google.com/file/d/1jZTfEVjwmL9wT5n...b-K/view?usp=sharing
Time to create page: 0.281 seconds
