mqtt-publisher
1 year 9 hours ago #337677 by CADdy
mqtt-publisher was created by CADdy
Hi all,
I experimented with the mqtt-publisher on a trial basis. It works well so far, but I can't publish more than 10 HAL pins. Even if there are more than 10 parameters under keys=, only the first 10 are transmitted. Does anyone know if I'm doing something wrong? I followed the mqtt-publisher instructions exactly.
Thanks for help
Peter
1 year 8 hours ago #337679 by unknown
Replied by unknown on topic mqtt-publisher
Did you notice the bit where each token is limited to 255 characters and to get sound this you can use multiple "keys" entries ?
It's hidden in under the examples heading.
If you have no further luck it may be of interest to raise an issue on the GitHub page.
1 year 8 hours ago - 1 year 8 hours ago #337681 by CADdy
Replied by CADdy on topic mqtt-publisher
When I create multiple “keys=” entries one below the other, LinuxCNC no longer starts:
Preparing LinuxCNC2MQTT info: Publishing MQTT message (devices/linuxcnc/machine): {"halui.axis.x.pos-relative": -84.95, "halui.axis.y.pos-relative": -92.95, "halui.axis.z.pos-relative": 24.496, "halui.joint.0.is-homed": false, "halui.joint.1.is-homed": false, "halui.joint.2.is-homed": false, "mqtt-publisher.period": 10} qtdragon_hd_postgui.hal:30: Unknown command 'keys=halui.estop.is-activated,halui.tool.number,halui.machine.is-on,halui.program.is-running,halui.mode.is-auto,halui.mode.is-manual,halui.mode.is-mdi,halui.mode.is-teleop' info: MQTT connected: Connection Accepted. Shutting down and cleaning up LinuxCNC... task: 526 cycles, min=0.000012, max=0.011844, avg=0.009461, 0 latency excursions (> 10x expected cycle time of 0.010000s) Note: Using POSIX realtime LinuxCNC terminated with an error.
My configuration:
loadusr -W mqtt-publisher \
--mqtt-broker=[MQTT]BROKER --mqtt-user=[MQTT]USERNAME \
--mqtt-password=[MQTT]PASSWORD \
keys=halui.axis.x.pos-relative,halui.axis.y.pos-relative,halui.axis.z.pos-relative,\
halui.joint.0.is-homed,halui.joint.1.is-homed,halui.joint.2.is-homed
keys=halui.estop.is-activated,\
halui.tool.number,\
halui.machine.is-on,\
halui.program.is-running,\
setp mqtt-publisher.period 1
setp mqtt-publisher.enable 1
Peter
Last edit: 1 year 8 hours ago by CADdy.
1 year 6 hours ago - 1 year 6 hours ago #337688 by unknown
Try this for the keys
keys=halui.axis.a.pos-feedback,halui.axis.b.pos-feedback,\ halui.axis.c.pos-feedback,halui.axis.u.pos-feedback,\ halui.axis.v.pos-feedback,halui.axis.w.pos-feedback,\ halui.axis.x.pos-feedback,halui.axis.y.pos-feedback,\ halui.axis.z.pos-feedback \ keys=halui.estop.is-activated, halui.joint.0.is-homed,\ halui.joint.1.is-homed,halui.joint.2.is-homed,halui.joint.3.is-homed,\ halui.joint.4.is-homed,halui.joint.5.is-homed,halui.joint.6.is-homed,\ halui.joint.7.is-homed,halui.joint.8.is-homed \ keys=halui.machine.is-on,halui.max-velocity.value,halui.mode.is-auto,\ halui.mode.is-manual,halui.mode.is-mdi,halui.mode.is-teleop,\ halui.program.is-running
I see what you mean, even when it starts with multiple key entries only the last group of keys get sent
Last edit: 1 year 6 hours ago by unknown.
11 months 4 weeks ago - 11 months 4 weeks ago #337721 by CADdy
With your settings, I only receive 7 values.
After removing the axes and joints that are not present on my milling machine, the result is the same - only 7 values are received. Sorry, I don't understand the principle of keys entries.
I have now shortened the list to 9 entries and am only using one key= statement. This allows me to transfer all 9 values.
halui.joint.0.is-homed,halui.joint.1.is-homed,halui.joint.2.is-homed,\
halui.estop.is-activated,halui.machine.is-on,halui.program.is-running \
Peter
Last edit: 11 months 4 weeks ago by CADdy.
11 months 4 weeks ago #337722 by unknown
Like I said it may be worth raising an issue on GitHub as the actual behaviour does not match the behaviour in the docs.
Time to create page: 0.056 seconds
