Turning single axis on and off
5 months 3 weeks ago #346170 by Ul
My machine is a small horizontal boring machine with three axis DC servos and lead screws, which I would like to change to ball screws.
If I want to operate the machine manually, I simply turn everything off using the red button in axis (F2), but with ball screws I would need to enable/disable single axis using let's say hardware buttons. Would this be possible?
Currently I am using AXIS 2.9.8 with 7i92.
5 months 3 weeks ago #346175 by PCW
Replied by PCW on topic Turning single axis on and off
I would be possible to disable an axis in hal,, the difficulty is returning to LinuxCNC control
without either generating a following error or a dangerous situation where you get a fast
uncontrolled return to the axis position before the axis was disabled.
5 months 3 weeks ago #346179 by tommylight
5 months 3 weeks ago #346218 by Ul
Replied by Ul on topic Turning single axis on and off
Thank you. I've already tried to increase ferror in the ini file to 200mm to deactivate following error completely. I can cut off the motor drivers power supply and turn the handle, but the axis travels back automatically when reactivated. Restarting the program every time is not an option, so I will probably end up building small encoder handwheels using HEDS encoder from Aliexpress. Do handwheels at least work in MDI mode, or do I need to change the tab every time I want to operate it manually?
I am using this kind of driver from Aliexpress:  de.aliexpress.com/item/1005009677397224.html
It's wired directly to the 7i92 and it drives small coreless motors with HEDS encoder, so the servo loop is done by the mesa card. No Geckos crawling in my machine.
5 months 3 weeks ago #346220 by tommylight
...so the servo loop is done by the mesa card.
OK, see PCW's post up.
I think with normal step/drive controlled drives it can be done by disabling the drives as the loop is not closed in LinuxCNC, but i never actually tried it.
5 months 3 weeks ago #346221 by spumco
One way would be to have a hardware (or software) button that sequentially
  • Un-homes the axis
  • Resets the encoder to zero
  • Disconnects the encoder from LCNC
  • Then disables the drive
Re-enabling it would be:
  • Zero encoder
  • Connect encoder to LCNC
  • Enable drive
  • Re-home axis/joint
This sequence should - I think - take care of the following error problem with no sudden servo movements to 'catch-up' to a massive following error.
LCNC is always disconnected/reconnected to an encoder at zero counts.
NOTE: this process would not be available while running gcode program.  i.e. no stopping in the middle of a program, manually jogging away, and then re-starting the program.
