Properly Installing Linuxcnc as a Bootable USB
- Aldenflorio
- Thank you received: 15
21 Oct 2022 18:03 - 21 Oct 2022 18:07 #254704
by Aldenflorio
Properly Installing Linuxcnc as a Bootable USB was created by Aldenflorio
I am building another plasma machine soon. I have previously built them with linuxcnc and have used a bootable USB drive to operate it all. Though I believe when I downloaded and set up linuxcnc it want complete.
often I had some files missing for basic operation causing a lot of issues with adding and altering programs. A lot of times things would be missing or off after I configure my machine ini wise. Also I would run into some odd errors.
for this machine I have a lot of time to figure everything out, with that said, how do I create a linuxcnc based bootable USB that is perfectly complete or proper? Or how do I avoid an incomplete installation?
i will be using the following sheetcam, Inkscape, hyperthem45, mesa7i76e, thcad-10, proximity sensors, and enclosed loop motors
Last edit: 21 Oct 2022 18:07 by Aldenflorio.
- Thank you received: 7488
21 Oct 2022 18:44 #254713
Replied by tommylight on topic Properly Installing Linuxcnc as a Bootable USB
Normal install on a USB is very slow.
To safely install on a USB drive as a full install:
-remove any hard drives or SSD or NVME from the PC
-insert the USB containing the burned ISO
-boot from it, start the installation
-before proceeding, insert the other USB
-now proceed as normal
Do not use USB drives with the same size to easily differentiate what is what.
The following user(s) said Thank You: arvidb
22 Oct 2022 19:38 #254795
github.com/LinuxCNC/linuxcnc-live-build
and edit the package list:
github.com/LinuxCNC/linuxcnc-live-build/...e-lists/desktop.list
I have forgotten the actual command to build the .ISO file. something like
I can check my notes when I get home if you want to go this route.
Replied by andypugh on topic Properly Installing Linuxcnc as a Bootable USB
The stock LinuxCNC distribution is built with live-build. You could clone this git repository:how do I create a linuxcnc based bootable USB that is perfectly complete or proper? Or how do I avoid an incomplete installation?
lb config
lb buildI can check my notes when I get home if you want to go this route.
- Aldenflorio
23 Oct 2022 01:24 #254813
by Aldenflorio
Replied by Aldenflorio on topic Properly Installing Linuxcnc as a Bootable USB
Would it be better to set it all up on a hard drive? The point of me trying to do it on a usb would be that it’s easier to replicate. Or so I think
24 Oct 2022 10:20 #254891
What I described was how we create the bootable "LiveCD" image which includes both a usable disk image _and_ the installer to copy that to a PC.
If you simply want to create a disk image without the installer then there are likely to be better and easier choices. (I just don't know what they are)
- Aldenflorio
24 Oct 2022 16:47 #254921
by Aldenflorio
Well, essentially what I plan on doing is creating a computer that I design and calibrate as a base model for all my future machines. I want to get everything exactly how I want it even with sheet cam and all. Then I’ll be able to just clone the whole set up and keep this computer as a continual base. I want to keep adding and perfecting it as well. So whatever will work best for that.
i need a monitor and a power cord then I’ll be able to start setting it up
24 Oct 2022 18:19 #254933
Maybe look at Clonezilla.
- angelicajohn
- Visitor
01 Nov 2022 06:36 #255636
by angelicajohn
Replied by angelicajohn on topic Properly Installing Linuxcnc as a Bootable USB
I really liked the way you highlighted some really important and significant points.
- Aldenflorio
01 Nov 2022 09:15 #255640
by Aldenflorio
What?
01 Nov 2022 12:08 #255656
Angelica forgot the links!
She will be back later to add them.
I will be waiting...
Time to create page: 0.176 seconds
