It occurs to me that not only have I changed the hard drives and motherboard (old rig was IDE, new is SATA) but I've also changed the parallel port card.
Ran the lspci utility, but I'm not able to identify the port addresses. This appears to be the applicable section, but I could be wrong...
04:00.0 Memory controller: NetMos Technology PCI 1 port parallel adapter (rev 01)
Subsystem: LSI Logic / Symbios Logic Device 0010
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR+ INTx-
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at 1010
Region 1: I/O ports at 1018
Region 2: I/O ports at 1020
Region 3: I/O ports at 1028
Region 4: I/O ports at 1030
Region 5: I/O ports at 1000
Kernel modules: parport_pc
Attached is the complete file.
Can someone help me decipher the actual port addresses for both parallel ports?
Tom
