A Haas MiniMill like Configuration
10 years 5 months ago #74901 by webmanoffesto
Sparky961 wrote: However, being able to intelligently modify g-code that comes from a CAM program is in my opinion an essential skill that many machinists lack. Also, memorizing a subset of the g-code for a particular machine and running certain MDI commands can greatly improve your efficiency and connection with a machine.
Yes, that is exactly what I want to do.
9 years 10 months ago #84009 by FDP
Can you elaborate on what kinds of tweaks you do regularly on a machine that can't be done in CAM? I am still getting my feet wet with CNC (5 years in I am no longer ashamed of my skills, but not a master yet). The only thing I regularly do is change G83 to G73 in order to fix peck milling and tweak the parameters. I can speak Gcode pretty well, but have never had to use work offsets on the tiny machines I have mostly used in the past, so am still getting used to those.
9 years 10 months ago #84027 by Todd Zuercher
It depends a lot on the code. I'm sure that the most common adjustment is a depth adjustment, which can usually be a very simple find and replace change with most 2.5-D code. If the code is optimized for using tool diameter offsets, minor changes in part size can be made there. But with parametric coding, the effect of minor changes can be very significant, and only limited by your coding skill and imagination.
The following user(s) said Thank You: FDP
9 years 10 months ago #84071 by FDP
Thanks for explaining! I really haven't used parametric coding at all - it's quite interesting. Most of the work I do has complex geometry but is still 2.5D, so it would have been very useful in the past to allow for certain things to be more easily adjustable in machine.
9 years 10 months ago #84237 by andypugh
FDP wrote: Can you elaborate on what kinds of tweaks you do regularly on a machine that can't be done in CAM?.
There is an example here: bodgesoc.blogspot.co.uk/2016/11/cams.html
160 lines of G-code to make a 7-row, 10-position cam.
If I want different rows or positions, or (especially) a different cam pattern, I just need to tweak a couple of parameters at the top, and run the same code again.
This is a _lot_ less trouble than re-modelling the cam in CAD to run the CAM again. And, in this case, the cam pattern is much clearer to see as 0 and 1 in the G-code than in a 3D model.
9 years 10 months ago #84347 by FDP
Awesome! I will check this out!
Time to create page: 0.107 seconds
