Converting Sieg SX3 to CNC
10 years 2 months ago - 10 years 2 months ago #79357 by cparsons
Getting close now...fairly fundamental question, my stepper motors have perhaps a meter of cable attached (8 wires) and I am looking at ways to connect these to the (homebuilt) controller?
What is the general approach, try and put a sleeve over the cables and add an extension as necessary?
Cut these cables short and fit shielded cable from the motor to the controller? (in which case attach a small box to the motor with the connections protected inside??)
I am trying to cope with the shielding issue and showers of metal chips/cutting fluid over the electrical stuff!
Anyone know a source for some appropriate 4 core + screened cable? (by the metre preferably)
While I am setting up/testing I have wired the motor cables direct to 4 pin XLR plugs/sockets but they will certainly not be long enough when fitted to the mill and are a bit exposed in my opinion
Chris
Last edit: 10 years 2 months ago by cparsons. Reason: typo
10 years 2 months ago #79421 by andypugh
Replied by andypugh on topic Converting Sieg SX3 to CNC
cparsons wrote: Cut these cables short and fit shielded cable from the motor to the controller? (in which case attach a small box to the motor with the connections protected inside??)
One possibility: www.zappautomation.co.uk/electrical-prod...back-cover-ip40.html
As you are using meters I am guessing you are in the UK:
Lots of oil-resistant drag-chain compatible cable here:
www.rapidonline.com/drag-chain-cable
I am not a huge fan of XLR, I rather prefer: www.maplin.co.uk/p/neutrik-nlt4mp-4-pole...akon-connector-n50gb
The following user(s) said Thank You: cparsons
10 years 2 months ago #79423 by andypugh
Of course, when I first started playing this game and was still trying to do stuff on the cheap, I came up with:
goo.gl/photos/TaCxCDVN9RSjSvwi6
The wires are soldered and heat-shrunk inside the conduit (joinst staggered) and the flex conduit is crimped into the aluminium adaptor thing.
This does involve drilling and tapping holes in the stepper-motor end-cover, though.
10 years 2 months ago #79424 by cparsons
Replied by cparsons on topic Converting Sieg SX3 to CNC
Thanks very much - covers look ideal but I have Nema 34 motors and the price *choke*
I buy stuff from RapidOnline and didn't think to check them for this sort of cable - ideal :)
I already have the XLR plugs and sockets - I have never seen the ones you mention but
will have a look at them, thank you - the XLR connections will be away from the mill so I am not
so concerned about chips and fluid
Yes, I am in the SW of the UK
Best wishes
Chris
10 years 2 months ago - 10 years 2 months ago #79426 by cparsons
That was the sort of thing I was thinking about - I have found some polyester braided sleeving to keep them together and provide some protection and am looking for the metal equivalent - my DRO kit from China came with this sort of thing protecting the scales and it is perfect, nice and flexible.
I am loath to cut the stepper wiring short, would rather coil it up and stuff it in a case attached to the stepper with some better cable attached - decisions decisions
Chris
10 years 2 months ago - 10 years 2 months ago #79427 by andypugh
cparsons wrote: Yes, I am in the SW of the UK
Zapp Automation and Motion Control Products are both in Bournemouth. Marchant Dice are near Barnstaple.
Last edit: 10 years 2 months ago by andypugh.
Time to create page: 0.211 seconds
