What would you guy's recommend for encoders?
- Catch22
- Thank you received: 17
25 Oct 2018 22:38 #119414
by Catch22
What would you guy's recommend for encoders? was created by Catch22
I have an cnc knee mill with sem servo motors and just bought some AMC servo drives to replace the original ones. The mill has tachs on the motors and A10 linear scales, would you guys recommend using the linear encoders or should I ad an encoder on each motor instead, just want what be best.
Any input on this would be greatly appreciated.
Thanks Mike
Thanks Mike
26 Oct 2018 11:49 #119437
Replied by andypugh on topic What would you guy's recommend for encoders?
if the drives support tachometer input and velocity mode then I would use that and close the position loop with the linear scales. In theory that gives the best accuracy.
The following user(s) said Thank You: Catch22
- Catch22
26 Oct 2018 14:06 #119446
by Catch22
Replied by Catch22 on topic What would you guy's recommend for encoders?
Yes they do support tachometer input, thank you for your help.
- OT-CNC
- Thank you received: 75
26 Oct 2018 14:35 #119450
by OT-CNC
Replied by OT-CNC on topic What would you guy's recommend for encoders?
I would keep the linear encoders on the X and Y. Is this for the anilam project you posted on before?
If so, you need to understand that the ball screws on the older machines were not super high precision and positional accuracy was achieved with the linear encoders. I was reminded of that by an Anilam repair specialist.
If you have rotary encoder on the Z ball screw, I would replace that with a US-digital product. I used one that happen to be a direct fit with higher resolution. I can look for the part number if you're interested.
To get it going, I would try to use the boards in the machine as previously suggested if they still work and read in the encoder to a 7i77 etc.
- Catch22
26 Oct 2018 14:42 - 26 Oct 2018 14:43 #119451
by Catch22
Yes it is for the anilam crusader m control. I don't know if the old drives work, and I have purchased new AMC drives that I would like to use.And yes to the z axis encoder info.
Thanks for your help.
Thanks Mike
Thanks Mike
Last edit: 26 Oct 2018 14:43 by Catch22.
- OT-CNC
26 Oct 2018 15:34 #119454
by OT-CNC
- Catch22
26 Oct 2018 16:34 #119460
by Catch22
Awesome, and thanks.
- Catch22
26 Oct 2018 17:59 - 26 Oct 2018 18:22 #119473
by Catch22
Last edit: 26 Oct 2018 18:22 by Catch22.
- Thank you received: 4149
26 Oct 2018 18:28 #119474
Replied by rodw on topic What would you guy's recommend for encoders?
That and the switch drawn beside it are a relay. You've circled the relay coil (low voltage side)
- Catch22
26 Oct 2018 21:18 - 27 Oct 2018 01:17 #119485
by Catch22
OK thank you, but is it really necessary to have a relay there, I wasn't planning on putting one in.
Thanks Mike
Thanks Mike
Last edit: 27 Oct 2018 01:17 by Catch22.
Moderators: piasdom
Time to create page: 0.516 seconds
