Fehlmann Picomax 100 Retrofit
21 Aug 2023 17:52 #278630 by Zbyna
Replied by Zbyna on topic Fehlemann Picomax 100 Retrofit
Hello,
I would like to ask you, if you have any original remaining parts. I Have Picomax100 too, but still with TNC155. I´m looking for handbox and boards, because the board for A-axis is missing. Eventual I would like to buy other remaining parts.
Thank you very much
Have a nice day
  • anfänger
  • anfänger's Avatar Topic Author
  • Platinum Member
  • Platinum Member
23 Aug 2023 09:16 #278757 by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
I still got some of the old parts.
Like transformer, servo drive, two servos.
Spindle motor, spindle drive and handbox.
The tnc155 and two servos are already sold.
But I can’t tell if they worked properly, cause I never really tried to run them. The lower panel I might also got one left.
Cheers Patrick
23 Aug 2023 17:55 #278813 by Zbyna
Could we arrange next by email? Could you send me photos please? I don´t know how to use the personaly message in this forum. Thank you very much.
  • anfänger
  • Platinum Member
  • Platinum Member
25 Aug 2023 07:33 #278907 by anfänger
I think PM don’t work here.
Do you have Facebook or instagram where I can you contact you?
28 Aug 2023 18:22 #279189 by Zbyna
Ok, could you send me messege on Facebook profile "Hana Vašicová (Hamerníková)", please. She is my wife. Thank you very much.
  • anfänger
  • Platinum Member
  • Platinum Member
29 Aug 2023 12:34 #279278 by anfänger
I contacted your wife. You can remove her name now above. If she forwards me you mail, this should be a solution withou publicly exposing mail addresses
  • anfänger
  • Platinum Member
  • Platinum Member
08 Aug 2024 18:10 #307271 by anfänger
Long time no news here...
to make it short, I installed a Mesa 7I85S and with a lot of help from here I got my servos running with digital instead of analog control.
and now its time to annoy the probe_basic guys cause I am trying migrate to linux 2.9.3 to use steppers with index for homing
The following user(s) said Thank You: RotarySMP, tommylight, Unlogic
12 Aug 2024 17:30 #307570 by RotarySMP
Replied by RotarySMP on topic Fehlemann Picomax 100 Retrofit
"Its alive"!
  • anfänger
  • Platinum Member
  • Platinum Member
13 Aug 2024 15:02 #307639 by anfänger
Yes! I am really happy that I've solved als the Hardware issues.
on the wiring todo list only open points are home and brake of the 4th axis.
And the Tool length sensor.
open software topics are:
migration to 2.9.3 maybe changing from probe_basic to qtdragon
Toolchange seqence
home with index.
Drive feedback
Nice to haves
Load feedback from drives and Spindle
Linear Scales for the Colum (Extension for Z Travel axis to compensate Tool length) To keep the Quill travel as short as possible and make the tool length sensor fully usable.
  • anfänger
  • Platinum Member
  • Platinum Member
04 Sep 2024 09:18 - 07 Sep 2024 10:58 #309343 by anfänger
So....
the machine is runnung linuxcnc 2.9.3 now. I use cutom tabs with probe basic.
and will tackle lubrication and toolchange next.
for lube any suggestion which component works best?
For my lathe I have one, but it kind of lubes to much. cause it runs every start and also the timer runs when idle. its only for the ways, so i didn't bother when there was to much oil.
On the Picomax I would prefer if the timer would keep its value even on restart and I need two instances one for the Spindle and one for the ways.
Is there a suitable component already done?
was unnecessary the timer is integrated in the bube pump by a mechanical reduction of the motor.
Last edit: 07 Sep 2024 10:58 by anfänger.
Moderators: piasdom
Time to create page: 0.121 seconds
