Fehlmann Picomax 100 Retrofit
- db1981
- Thank you received: 276
10 Apr 2022 19:51 #239850
by db1981
Replied by db1981 on topic Fehlemann Picomax 100 Retrofit
may be you could use an board of the old control to interface the scales, like the others do with 3x exe board from the phillips control at old mahos.
the control has worked at ttl level, so there must be an part which converts 11ua to ttl....
- anfänger
- Thank you received: 256
10 Apr 2022 20:25 #239853
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
The scales were directly connected to the Heidenhain 155 control, no box or card in between.
- anfänger
11 Apr 2022 08:14 #239899
by anfänger
is there a way of find out how many increments the Z Axis encoder had?
ROD 456 5000 02S09-04 ID Nr 295 459 D.Nr. 14 165 553 A D5
Thanks Patrick
Thanks Patrick
- db1981
11 Apr 2022 08:39 #239903
by db1981
TNC155, then you will need Exe Boxes. This unit could not be used for interfacing.
ROD456 5000 , should have 5000 periodes per turn.
If this is an 5mm ball screw, will give 0.001 scaling.
- anfänger
11 Apr 2022 13:29 #239921
by anfänger
Thanks, that will help finde replacement. The Z Axis encoder is on an spur gear driving the quill (kind of rack and pinion), so I want at least the same resolution as the existing one. I guess I'll replace the scales and encoder.
many thanks
Patrick
many thanks
Patrick
- RotarySMP
- Thank you received: 593
22 Apr 2022 13:08 #240886
by RotarySMP
Replied by RotarySMP on topic Fehlemann Picomax 100 Retrofit
Sorry I nissed that your control had intergrated A/D conversion. Since two channels of my EXE were DOA, I bought replacement 601D EXE's off Ebay.de.They only cost about €60-80 per unit, and only need 5V, rather than 5V and 12V of the original.
I never really worked out the model numbering, so I ended up with one returning the 1µm resolution same as the original. The other one ouputs 5µm resolution. Doesn't make any difference in practice to what I use the MAHO for so far.
Mark
Mark
- anfänger
25 Apr 2022 10:25 - 25 Apr 2022 13:00 #241185
by anfänger
there ist nothing you have to apologize for.
There are three boxes on ebay for 75€ each.
Cables cut, so I would need to open and rework them. I guess 1F is 5 µm and 5F 1 µm but it's just a guess when the numbers are for the interpolation.
Using them would be cheaper, not sure if quicker, cause I have to redo the connectors from the encoders and rewire the boxes.
Still not really sure what to do.
Change to TTL scales / Encoder oder buying AD boxes.
Changing is roughly triple the cost compared to the AD Boxes.
Which now kicks me to the AD boxes.
Cause the new spindle motor wasn't cheap.
Thanks Patrick
EDIT: F*** it, I bought two of these things for a special deal. This way I can have a look at X and Y an test Z. For U then O can see If I change the encoder or by a third AD box. same for the A-Axis but that for later anyway
Thanks Patrick
Last edit: 25 Apr 2022 13:00 by anfänger.
- anfänger
26 Apr 2022 19:42 #241324
by anfänger
- anfänger
28 Apr 2022 06:58 #241439
by anfänger
not much but, I opened them, they look quite nice.
just to figure out, that I ran out of cable now need to wait for some to arrive. With some luck in can look at it on the weekend.
Also need to think about where to lace the boxes, cause the encoder cables are to short to lay it on the bottom.
I should be able to reroute them and make new entry point in the cabinet.
- RotarySMP
03 May 2022 09:44 #241901
by RotarySMP
I also have two stand alone boxes and one original EXE channel in operation. I barely notice that one axis has only 5µm resolution, since I only touch off to Hundredths. I have no real expectations of being able to do anything to µm tolerance.
Mark
Mark
Moderators: piasdom
Time to create page: 0.197 seconds
