Fehlmann Picomax 100 Retrofit
- anfänger
- Thank you received: 256
06 May 2022 07:41 #242105
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
I have rewired the first Box yesterday:
I guess you are right with not noticing the difference between 5 an 1µm
But with the box open an having the manual I guess you can change between 1 and 5 µm per jumper setting. But not sure just a guess.
If I have 5µm resolution on the scales now I will change the Z axis my 3600 line encoder (bought this for the spindle, but the new motor hat its own) I have here instead go the 5000 which is in there right now. I its 1µ m I'll buy a third box.
Not sure what to do with the A Axis, this will be a project for later anyways.
Tanks Patrick
Tanks Patrick
- anfänger
03 Jul 2022 16:18 #246515
by anfänger
Installed all boxes including a third one.
youtube.com/shorts/AuqmkElyFVI
a bit odd is when I look at the encoder counts I have 1000 per mm when running against a dial indicator
but I needed to adjust my input scale to 40 in order get the DRO to also run correctly, never had this issue.
My new spindle motor arrived in port today, so I guess It can have a look at it and figure out how to mount it on the mill soon.
- Kevin_Pawlus
- Thank you received: 6
14 Jul 2022 19:58 #247318
by Kevin_Pawlus
Replied by Kevin_Pawlus on topic Fehlemann Picomax 100 Retrofit
I bought the same boxes for my TOS FNG 32 Retrofit.
How do you know how to plug them in to the Mesa board? Is there a manual on these?
Best regards
Best regards
- anfänger
25 Jul 2022 18:43 #248274
by anfänger
Sorry forgot to answer you, a manual can be found here:
www.atechauthority.com/pdf/EXE_602D_604C_605C.pdf
Connectors the are more or less standard then an work easily with mesa.
But look what the cat dragged in:
mad some mistake with the chose of the forwarder, should have used my standard one would have been cheaper.
anyway now the servo with drive is here:
next is to check if it's plug an play on the mechanical part, if not it will be funny, with none of mc CNC mills running at the moment
- anfänger
27 Jul 2022 10:14 #248402
by anfänger
- anfänger
28 Jul 2022 14:10 #248537
by anfänger
The following user(s) said Thank You: arvidb
- Kevin_Pawlus
28 Jul 2022 14:32 #248541
by Kevin_Pawlus
Looking good
Is that a Siemens DC motor?
It looks very much like what I have on my machine, I hope I don't need to replace it.
- anfänger
28 Jul 2022 19:43 #248578
by anfänger
It's a DC motor but not Siemens and I am replacing it I have a 3 Phase servo here. Which I hope will fit nicely.
I had some trouble with the drive unit and needed an encoder to run with linuxcnc. So I decided to change it.
- anfänger
30 Jul 2022 19:35 - 30 Jul 2022 19:41 #248691
by anfänger
Last edit: 30 Jul 2022 19:41 by anfänger.
- anfänger
30 Jul 2022 19:46 #248692
by anfänger
Moderators: piasdom
Time to create page: 0.246 seconds
