Bridgeport VMC760 retrofit
1 year 5 months ago #327792 by spincycle
Thanks Tommylight.
I had a good read through your tutorial last night. Very informative.
Unfortunately it's the servo drives that are busted in my machine. I assume the procedure is similar for newer drives if running analog? I would tune the velocity/torque in the drive software, then tune position through Linuxcnc.
It looks like a few of the modern servo drives I've looked at have encoder outputs. Those will just run back into a Mesa card like the 7I97?
1 year 5 months ago #327793 by spincycle
Hi Langdons,
Yeah definitely affordable!
We run 415v 3ph in Australia. Weirdly enough there isn't a huge amount of aliexpress drives that cater to that voltage.
Inovance, Leadshine and Delta do however offer 400v stuff which is nice.
1 year 5 months ago #327800 by tommylight
Yes.
Yes.
Yes.
3 for 3, nice! :)
New drives can also be controlled by step/dir and also have encoder outputs, and those can again be used in LinuxCNC.
And there are several boards from Mesa that can be used, not just 7i97, a lot of combos there so when you are ready to order stuff, ask here first as we have the Mesa Master with us here, always, in the form of PCW.
1 year 5 months ago #327807 by tommylight
We have 3 phase power in houses, always, rated at 3x380V +-10% and can pull 16A at home from any plug, 32A in workshops/garages.
Lately the local provider started complaining if we pull over 15KW over long duration's, i do not blame them, we have 100A at our disposal.
To spite Americans (since i still refuse to go there despite being granted a Green Card 17 years ago), we can charge a Tesla at home with 22KW on any socket around the house, 60KW if we push it! :)
And that is with no permissions or requests or installing superchargers!
The following user(s) said Thank You: COFHAL
1 year 5 months ago #327888 by tommylight
50 hz is inferior to 60Hz b/c transformers, motors, etc. need to be bigger and more expensive.
Was this from chatGPT?
The only valid difference is the induction motors spin faster at 60Hz, everything else is pretty much irrelevant.
1 year 5 months ago #327962 by spincycle
Yes.
Yes.
Yes.
3 for 3, nice! :)
Ace! Thanks Tommylight.
I have a 7i96 kicking around from a machine that never got off the ground, but I assume the lack of encoder inputs means I should use a different card.
This machine originally had rapids of 32,000mm/min with 16mm pitch ballscrews - 2000rpm on the axis. Would there be any benefit of analog over step/dir or even ethercat, to maintain such rates of speed and precision?
I just got off a 10hr flight. I took the original Bridgeport machine schematics with me to asses the control side of things. It looks like the Heidenhain output a 24v (sourcing?) signal to a bank of relays to control the solenoids, enables, mag motors, contractors etc. I assume a Mesa card, like the 7i84U could take this role?
It'd be bloody awesome if I could just retain these original distribution/control boards and halve the amount of wiring required!
Time to create page: 0.143 seconds
