Forum Header
Inverting input in stepConf causes error loading
10 years 9 months ago #68995 by summetj
I have a machine that works with Mach3, so I'm happy that the hardware works. I want to use LinuxCNC, so I installed the latest distro image onto a computer and fired things up. The Parport test script shows that my limit switches are seen by the hardware, and I can step all of the axis, so again, hardware is fine.
When I run the StepConf wizard and create a configuration the 3 axis run back and forth just fine with the axis tester. When I run LinuxCNC it loads but gives limit switch errors. SO, I went back into stepConf and inverted my limit switches (they are active when grounded). HOWEVER, when I do this LinuxCNC fails on loading due to an error message:
sim_hardware.hal:20: Pin 'parport.0.pin-10-in-not-fake' does not exist.
(pin-10-in-fake works just fine, but for some reason when I invert the limit/home switch the hal config file that StepConf wizard generates has this problem.)
Linux CNC version 2.7.3
I'm not sure of the stepconf version, but it was whatever is bundled in the standard 2.7 ISO image that I downloaded just a few days ago.
Anybody run into this before and know a (hopefully easy?) fix?
Thanks,
Jay
Lots of more information about my machine home/limit switches is here:
www.summet.com/blog/2016/01/17/how-to-co...ome-switches-e-stop/
10 years 9 months ago #69001 by andypugh
It would probably have been easier to directly import the Mach3 config on the first page of Stepconf
I am puzzled whet the sim_hardware.hal file came from, that is inappropriate for a real config.
What happens if you just delete the reference to that file from the INI file?
10 years 9 months ago #69005 by cmorley
Are you sure it's 2.7.3 ? I think the ISO is 2.7.0 without an update. These sound like bugs that have been fixed by 2.7.3
Chris M
10 years 9 months ago #69011 by summetj
The first thing I tried was importing the mach3 file, but I had some problems with that so I just re-created it. The pin assignments and stepper speeds are not an issue, the axis tests on each stepper work just fine. The problem appears to be a config file issue when inverting the inputs.
10 years 9 months ago #69012 by summetj
The version reported by LinuxCNC is definitely 2.7.3.
I did install the updates (for both Debian and LinuxCNC repositories) after installing from the ISO image.
Perhaps the stepConf needs to be updated somehow? I wasn't sure how to find out the version number of StepConf (it doesn't show it anywhere on the screen when I was using it as far as I can tell.
10 years 9 months ago #69014 by summetj
andypugh wrote: It would probably have been easier to directly import the Mach3 config on the first page of Stepconf
The sim_hardware.hall file was created by the StepConf gui.
I tried commenting out the "source sim_hardware.hal" line from my ScanTek2000-sherline.hal file, but then the error messaged changed as follows:
ERROR: function 'sim-hardware.update' not found ./ScanTek2000-sherline.hall:15:addf failed
So I commented out the "addf sim-hardware.update servo-thread" line.
And then the error was:
Pin 'parport.0.pin-10-in-not' does not exist.
(This is from a line: net home-x <= parport.0.pin-10-in-not)
at this point, I stopped commenting things out, because that line looks very much like something I really want to have in my final config.
Time to create page: 0.111 seconds
