- Thank you received: 3
So basically keep all the tweaking to the dirhold and dirsetup values?PCW wrote: That wiki information is very out of date
I would just use a current linuxcnc's stepconf program to set the values in nanoseconds
wow, ok... color me confused.PCW wrote: Not sure you you would spend any time tweaking the setup and hold times.
Just set them to 20000 ns and be done with it, there is basically 0 cost to making
these larger than needed and 20000 ns will work for almost any drive.
