I'm a long time user going back to EMC. I had a slower machine that is now failing running older linuxCNC 2.7(? grub lists it as debian 3.4-9). It worked well with my servo system with Gecko drivers. This is on an R45 mill with large servos. I have 250cpr encoders, 1000cpr in quadrature. Coupled with the lead screw and timing belts, the system ran O.K. with jitter about 65us. It was limited by me to 60ipm. I would occasionally get a halt, usually lifting the Z axis that weighs 240lbs and stopping suddenly. I remember it ran smoothly up to maybe 70ipm but I would get halts after that. I rarely ran it in G0 speed, usually my G01 rapids were no higher than 50ipm. When I had a faster 3.2Ghz machine on the mill, I easily hit 130ipm and the acceleration was tuned to hit max speed in 90 degrees of the drive timing gear. But that faster machine died, so I put the slower one on because even with latency of 65us, it had much better latency than others I tried, most well over 100us.
I would like to get my DL380 G7 working but its latency is up around 110us. I have an old AMD64 machine that has less than 5us latency so I am going to use that for now. I tried turning everything off on the DL380, latency dropped from maybe 120us to 110us. It needs a graphics card I think but I can't find an inexpensive card for PCIE 1x, 2x or 4x max. the other issue is the parallel port on the DL380. So the AMD64 has 5us latency, a graphics card and the parallel port card works.
So if you are still following along, I would like to modify my config files taking a machine that was tuned at 65us latency running 60ipm to one with latency of 5us running 130ipm or even faster. I can easily change the speed in the config files but what else should be changed? Is there a doc that describes what stepconfig does so I can apply the changes manually to my old config files? Or should I use stepconfig, generate new files, and then copy in my specific changes? I can't remember all the timings and pulse counts per revolution, lead screw pitch and timing gear reductions. I know they are in the hal and machine files.
Anyway, thanks for the help on this one and to the others that helped on the thread I started with general questions. Last I was here, there wasn't a forum, we used a chat for support.
Thanks again,
Jerry
