Will or how do I make this work??
  • allenwg2005
  • allenwg2005's Avatar Topic Author
  • Elite Member
  • Elite Member
09 Apr 2013 08:40 #32449 by allenwg2005
Will or how do I make this work?? was created by allenwg2005
I have purchased a CNC Router built about 15+ years ago.
The 286 and it's software had to go.
I want to use an HP with a AMD Athlon, w/processor speed of 2.20 GHZ.
It's running integrated graphics with 64MB shared video memory.
The jitter is a little high given the shared graphics, (I think).
What is a good option here? (Or is there an option here).
I also need to replace the LPT ports because the boards from the old PC won't work with the newer PC.
The machine is using Anaheim Automation's DC stepper driver and motors.
Anaheim Auto suggested plan old LPT ports, so I have three of those en-route, I'm wondering if LPT boards from say Mesa would preform better and cut down on jitter.
Please let me know if I should make changes, and if so, how to go forward.
Thanks to all, Allen
09 Apr 2013 09:56 #32452 by Todd Zuercher
Replied by Todd Zuercher on topic Will or how do I make this work??
What Anaheim drives do you have?
Some of them use a little bit odd parallel port pin-out. (But I think these were only made for a certain machine manufacturer.)
They are probably half stepping unipolar drives and probably won't see a huge improvement going from software to hardware stepping.
The following user(s) said Thank You: allenwg2005
09 Apr 2013 15:46 #32462 by ArcEye
Replied by ArcEye on topic Will or how do I make this work??
.........The jitter is a little high
There are a huge variety of processors under the Athlon badge, some dual core some not.
If you have a single core try it with 8.04, if a dual core try it with isolcpus and 10.04
See
www.linuxcnc.org/index.php/english/forum...-the-latency-problem
www.linuxcnc.org/index.php/english/forum...me-latency-solutions
for that and more
  • allenwg2005
  • Elite Member
  • Elite Member
09 Apr 2013 21:46 #32484 by allenwg2005
Replied by allenwg2005 on topic Will or how do I make this work??
Todd, sorry I should have included that info.
Anaheim Automation Model #DPF 65003.
It's old, they have no information on it via the web.
Arceye, looks like I have some reading to do, thanks for your direction.
The integrated video isn't a problem?
09 Apr 2013 22:34 - 09 Apr 2013 22:36 #32486 by Todd Zuercher
That drive is functonally equivalent to its replacement the DPF72003
www.anaheimautomation.com/manuals/steppe...%20Users%20Guide.pdf
That is a unipolar, half stepping drive. (I have several of the 4 axis version laying around here). They should work fine with just an ordinary parallel port, provided the breakout board(s) you are currently using aren't to weird.
You will want to pull the cover off the drive and check the connections on the driver boards. They do sometimes burn up, but other wise seem pretty durable.
I have not gotten around to actually converting any of our machines that are still using Anaheim Automation step drives to LinuxCNC, other than bench testing to see that it would work. The machine I converted that did have an AA drive I converted to servos in the process. I might eventually get around to doing 1 or 2 machines with Anaheim Automation drives though.
Last edit: 09 Apr 2013 22:36 by Todd Zuercher.
09 Apr 2013 22:45 #32487 by ArcEye
It could be, but some are unproblematic.
Need to get the basics right first regards kernel, then things like trying different drivers, a video card etc.
  • allenwg2005
  • Elite Member
  • Elite Member
11 Apr 2013 20:24 #32564 by allenwg2005
Thank you again to both of you.
I'm just curious, would you lose any functionality using 8.4 rather than 10.4?
Is there any difference between the two were Linuxcnc is concerned?
11 Apr 2013 20:27 #32565 by BigJohnT
Replied by BigJohnT on topic Will or how do I make this work??
No functional difference as you can run the latest LinuxCNC 2.5 on both. In fact 8.04 in many cases runs lower latency on older hardware.
  • allenwg2005
  • Elite Member
  • Elite Member
13 Apr 2013 23:57 #32687 by allenwg2005
I decided to go with 8.04, the latency so far is much improved.
I did get this error message while updating though.
W: Failed to fetch security.ubuntu.com/ubuntu/pool/main/b/b...-2ubuntu0.1_i386.deb
404 Not Found [IP: 91.189.92.200 80]
Is this a concern?
What should I do if it is?
14 Apr 2013 00:30 #32692 by cncdreamer
Replied by cncdreamer on topic Will or how do I make this work??
Basically, this means the latest version of some dns utilities couldn't be installed because the update process couldn't reach a file server. In other words, it's not you, it's "them".
I wouldn't worry about it. The situation should resolve itself over time once the file server becomes reachable and your update manager runs again.
Regards,
Kent
Time to create page: 0.076 seconds
