Disabling screen saver
11 years 1 month ago #63028 by andypugh
Replied by andypugh on topic Disabling screen saver
GaryLa wrote: I've disabled them, I've set them to an hour, to 10 hours and every which way. No difference. Obviously there's yet another place it's being controlled.
Have you tried linuxcnc.org/index.php/english/forum/18-...r?limitstart=0#55601
11 years 1 month ago - 11 years 1 month ago #63029 by GaryLa
Replied by GaryLa on topic Disabling screen saver
Not yet. But when a user posted "what's the big deal, just change the screensaver" I felt compelled to answer him -- the screensaver parms are not effective.
I need to do some research on what else is affected by this "dpms" setting. A guy named Steve Rosenberg posted on his blog the following suggestion:
sleep 200
xset dpms 0 0 0
exit 0
He suggests the sleep is needed (at boot) because other parts of xfce seemed to change his settings later in the boot sequence. But he found that setting them after a delay worked. I haven't looked into any of it yet.
I also found this: wiki.archlinux.org/index.php/Display_Power_Management_Signaling . It's interesting that it states "Warning: XScreenSaver and xfce4-power-manager use their own DPMS settings and override xset configuration".
It's not the end of the world, it's just annoying.
Last edit: 11 years 1 month ago by GaryLa. Reason: new data
11 years 1 month ago #63031 by andypugh
GaryLa wrote: He suggests the sleep is needed (at boot) because other parts of xfce seemed to change his settings later in the boot sequence.
That is why setting it from the LinuxCNC INI file is a good idea.
It's a lot worse than annoying when you only have a touch-screen to wake the machine up again and don't know what you are going to hit..
11 years 3 weeks ago #63597 by RayJr
Replied by RayJr on topic Disabling screen saver
Is it possible to set in the linuxcnc.ini file, or is that a wish?
Ray M
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
11 years 3 weeks ago #63603 by andypugh
RayJr wrote: Is it possible to set in the linuxcnc.ini file, or is that a wish?
Dewey showed how to do it in the INI file here:
www.linuxcnc.org/index.php/english/forum...r?limitstart=0#55601
The following user(s) said Thank You: RayJr
Time to create page: 0.063 seconds
