Installing gedit
10 years 8 months ago #70438 by ArcEye
Replied by ArcEye on topic Installing gedit
Your /etc/apt/sources.list should have a line similar to
deb ftp.de.debian.org/debian wheezy main
in it.
If it did, having run apt-get update you should have found the gedit package with apt-get, because it is in main
synaptic is the GUI access to apt, won't help you if your repo paths are not right though
10 years 8 months ago #70439 by JohnK43
Replied by JohnK43 on topic Installing gedit
ArcEye
This is what is in my sources.list
# deb http.debian.net/debian wheezy main contrib non-free
# deb-src http.debian.net/debian wheezy main contrib non-free
deb http.debian.net/debian wheezy-updates main contrib non-free
# deb-src http.debian.net/debian wheezy-updates main contrib non-free
deb security.debian.org/ wheezy/updates main contrib non-free
deb-src security.debian.org/ wheezy/updates main contrib non-free
I am open to any suggestions.
10 years 8 months ago - 10 years 8 months ago #70440 by ArcEye
Your stanza to access the wheezy main repo is commented out ( that is what a # does)
Remove the comments, run
sudo apt-get update again
and then pull gedit with
sudo apt-get install gedit-common gedit gedit-plugins
It should work then
Last edit: 10 years 8 months ago by ArcEye.
10 years 8 months ago #70441 by JohnK43
I ran apt-get update
Generated what I believe to be warnings"W"
W: Duplicate sources.list entry buildbot.linuxcnc.org/ wheezy/master-rt i386 Packages (/var/lib/apt/lists/buildbot.linuxcnc.org_dists_wheezy_master-rt_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
Is this something I should be worried about or I can fix?
I do appreciate the help and time.
I have not yet tried to pull gedit.
10 years 8 months ago #70442 by ArcEye
It is just telling you the entry appears twice, I have no idea what you did to add master-rt in the first place.
Try pulling gedit and see what happens.
You should be able to just use
sudo apt-get install gedit gedit-plugins
it will get gedit-common and any other dependencies
10 years 8 months ago #70443 by JohnK43
I updated the master to get the foam 4 axis sim "X Y U V" for a wirecutter. I may have put some stuff in the wrong place.
I think what I am going to do is reinstall the live cd version see if I can install gedit then install the master of emc2
what you think???
Time to create page: 0.403 seconds
