- Thank you received: 19
it complains, but ultimately it works. dont really trust it tho
when i use address "0 out", it crashes on startup with:
oddwick wrote: for the homing sequence (XYZ on a XYYZ gantry), x homes normally, and only y1 homes while y0 is stationary (you can see how that doesnt end well...).
oddwick wrote: the error i get when i run linuxcnc:
Code:Linux parallel port @57360 not found
This seems odd, as 57360 = 0xE010
But your HAL has "loadrt hal_parport cfg="0x1060 out""
Which is a completely different number.
The dmesg and lspci both say that 0xE010 should be right.
andypugh wrote: Joints 1 and 2 should have JOME_SEQUENCE = -2
(negative numbered axes are homed as pairs)
