RockPro64
7 years 1 month ago #144257 by bellcopter
Replied by bellcopter on topic RockPro64
What distro did you use for your build? Those are some great looking latency tests. I'm looking to put a Mesa PCIE card into the Rockpro64 slot and make it a full-fledged controller, so this is very promising.
7 years 1 month ago #144259 by pl7i92
Replied by pl7i92 on topic RockPro64
with the fpga card or a eth you do not need latency at all
it is internal hardware steps that are generated
no software timing involved
7 years 1 month ago #144271 by Todd Zuercher
Replied by Todd Zuercher on topic RockPro64
Not completely true, you still need good enough latency to run the servo-thread, so Linuxcnc can do the motion planning and io sampling properly.
7 years 1 month ago #144273 by acondit
Replied by acondit on topic RockPro64
At the moment, I am running Stretch 9.8 with linux 5.0.7-rt5.
The following user(s) said Thank You: bellcopter
7 years 1 month ago #144282 by blazini36
Replied by blazini36 on topic RockPro64
pl7i92 wrote: with the fpga card or a eth you do not need latency at all
Yeah that's not quite true. Hm2 will generate steps and count encoders in FPGA fabric but the CPU still has to respond to the the stepgens or update from the encoders quickly. It's a hell of a band-aid to not great latencies but single ended GPIO isn't effected at all so if you had to read or write to I/O with something other than an encoder or stepgen it doesn't help at all.
Then again encoders and stepgens are probably the worst 2 things you can have to handle with software so it is much better for these.
Time to create page: 0.362 seconds
