- Thank you received: 96
spma wrote: Hi everyone!
I just want to leave my experience here because I've been able to successfully use an Pi3b+ with a Mesa 7i92 + 7i77 + 7i84.
True but I tested it thoroughly and the 2.5ms of servo_thread period was more than enough for a 30yo SLOW lathe with a maximum joint precision of 0.05mm... and it outputted that precision while machiningandypugh wrote: Interesting. You wouldn't normally expect that to work as the Pi3 ethernet is on the USB bus and that tends to make accurate timing impossible.
Yes, the Pi4 would now be a better choice, but we're talking about a project I started almost 2 years ago...andypugh wrote: Pi4 has he ethernet on the PCIe bus, and then the servo thread at 1mS works fine with an ethernet board.
