A good Barebones PC for real time LinuxCNC
  • thefabricator03
  • New Member
  • New Member
7 years 2 weeks ago - 7 years 2 weeks ago #147900 by thefabricator03
Replied by thefabricator03 on topic A good Barebones PC for real time LinuxCNC
I had that error when I first started when I was trying to use a old pc with a air cpu cooler that did not have a fan attached. The computer was throttling it self down to prevent the cpu overheating giving me latency issues.
Also what is that GUI that you are using?
Last edit: 7 years 2 weeks ago by thefabricator03.
7 years 2 weeks ago #147906 by LuisGZ
I disabled a couple of options more in the bios, and set up the fan at full speed. So far no message, I'll test it some more to make sure the warning stays off.
About the GUI, its Gmoccapy and PlasmaC with a system skin (joy blue), and some custom icons. I plan to redoing all of it, but I need to make sure the hardware works fine first :pinch:
6 years 3 months ago #174688 by RotarySMP
Are you still using the Gigabyte Brix 3150? I have one, but it is also freezing up under Debian 9. Without even starting LinuxCNC, as I am still trying to configure the PC.
Mark
6 years 3 months ago - 6 years 3 months ago #174745 by LuisGZ
That's right, still freezing with Debian 9. I just switched to Linux Mint. Its a considerably longer process to install base Linux Mint and patch it with RTOS, there's a guide on Gnipsel.com
In this way you have to install everything from scratch, including LinuxCNC, but also you can choose which branch of LinuxCNC you would like to use.
Last edit: 6 years 3 months ago by LuisGZ.
6 years 3 months ago #174746 by tommylight
This is much shorter and you can also choose between master and 2.8.
There is also a ready made ISO with everything included and ready to run 2.8.
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
6 years 3 months ago #174813 by RotarySMP
Interesting that we both had freeze problems under Debian but not under mint. A shame, as I prefer the debian interface, and it seems to have less overhead.
