latency and GRBL
7 years 16 hours ago #149364 by DangerToMyelf
I'm still in the research part of taking the plunge into CNC and have a question regarding latency.
The machine I have chosen to learn with, a Chinese 3018, uses an Arduino and GRBL. Is latency an issue with this setup?
7 years 16 hours ago #149366 by PCW
Replied by PCW on topic latency and GRBL
This is a LinuxCNC forum, GRBL is an alternate machine controller
so latency as such is not an issue (or at least the same issue)
Not sure what the best source of GRBL help is
The following user(s) said Thank You: DangerToMyelf
7 years 15 hours ago - 7 years 15 hours ago #149367 by DangerToMyelf
Replied by DangerToMyelf on topic latency and GRBL
I appreciate your thoughts. I am planning to use LinuxCNC as my OS. And I'm still figuring out how that will be set up to work with my machine and the other programs I'll be using such as Eagle for PCBs.
And how the PC could/will affect the 3018.
Last edit: 7 years 15 hours ago by DangerToMyelf.
7 years 15 hours ago #149369 by tommylight
Replied by tommylight on topic latency and GRBL
Linuxcnc is not an OS, it is a machine controller. Linux is an OS that Linuxcnc runs on.
7 years 14 hours ago #149371 by DangerToMyelf
tommylight wrote: Linuxcnc is not an OS, it is a machine controller. Linux is an OS that Linuxcnc runs on.
True. But it's all installed at the same time as far as I can tell. So why differentiate?
Nor does that answer my question that may not have been asked correctly. Which is "Will latency be an issue when using a Linux PC running LinuxCNC when sending commands to a GRBL based CNC? In other words, do I need to worry about latency when selecting a PC for my application? Or will any Linux capable PC do the job?
7 years 13 hours ago #149376 by Todd Zuercher
Replied by Todd Zuercher on topic latency and GRBL
As far as I know GRBL has no real time requirements for an interfacing PC, so latency should be completely irrelevant. (but I know next to nothing about GRBL)
Time to create page: 0.098 seconds
