Startech PEX2PECP2 Parallel port card
6 years 3 weeks ago - 6 years 3 weeks ago #185119 by seuchato
did you disable the pci/pce slots the cards are plugged i in bios?
also try this:
dmesg | grep par ... [ 3.974443] parport_pc 00:02: reported by Plug and Play ACPI [ 3.979007] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] ..,
tech specs found here say "Chipset ID ASIX - MCS9865". According to this post , it should "work fine".
Last edit: 6 years 3 weeks ago by seuchato. Reason: hint on dmesgm tecg specs and faq pci parport added
6 years 3 weeks ago #185147 by tommylight
A few days back i did test a StarTech PCI to parallel port card that did not work at all with Linux, the board is plain and void of any parts besides a small chip.
Used a NetMos card that always works.
The StarTech is recognized only as a PCI card under Linux, did not test any further.
6 years 3 weeks ago - 6 years 3 weeks ago #185150 by Clive S
No eBay APP ID and/or Cert ID defined in Kunena configuration
tommylight wrote: A few days back i did test a StarTech PCI to parallel port card that did not work at all with Linux, the board is plain and void of any parts besides a small chip.
Tom
I purchased 5 of these and they all work fine.
edit I noticed they are back on there website at the same price
Last edit: 6 years 3 weeks ago by Clive S.
6 years 3 weeks ago #185152 by tommylight
Clive S wrote: I purchased 5 of these and they all work fine.
Nice ! :)
I had a PCI one, not PCI-e, with a very small chip on it and nothing more, not even a resistor.
These on your link have some more electronic on them and a much bigger chip.
Never bothered to look at the chip no.
6 years 3 weeks ago #185241 by jeoslislo
I bought a second computer, an Optiplex 760, the PEX2PECP2 works OK.
In the first computer, a refurbished Optiplex 3010, it does not.
Maybe a bad motherboard.
6 years 3 weeks ago #185243 by tommylight
