Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
5 years 5 months ago #209628 by db1981
"lcec_conf exited without becoming ready" this tells you that lcec_conf is called but can't do its job correctly.. But normally there must be more infos in terminal whats going wrong with lcec_conf
Did you create an ethcercat_conf.xml file for your configuration?
Please post your hal and ini file, so we can take a look whats goin wrong.
5 years 5 months ago - 5 years 5 months ago #209734 by besriworld
Thanks ,
I tried to deal with the problem myself, but I can't handle it. I attach the configuration files. I'm trying to make one driver work with LinuxCNC. There can be a lot of nonsense inside. I'm just new to the world of Linux / LinuxCNC
File Name: ethercat_conf.hal
File Size:827 B
File Name: ethercat_conf.ini
File Size:1.46 KB
File Name: ethercat_conf.xml
File Size:1 KB
File Name: 6_ADTECH_X...5-21.xml
File Size:192.96 KB
File Name: dmesg.txt
File Size:51.91 KB
File Name: linuxcnc.report.txt
File Size:4.71 KB
The moderator can delete the post because I posted on another big topic !
Ethercat HAL driver
Last edit: 5 years 5 months ago by besriworld. Reason: The moderator can delete the post because I posted on another topic !
5 years 4 months ago #211169 by nic
Hi Grotius,
i have tried your iso-file and it works very well on my old HP Compaq 8000 Elite with Intel Core 2 CPU. Then i have tried it on my new self-assembled PC with AMD Ryzen 9 CPU. There i got an "Kernel Module not found" error.
Do you happen to know what the error could be? Could be the Bios settings an issue?
Thank you in advance.
Best regards,
Nic
5 years 4 months ago - 5 years 4 months ago #211214 by Grotius
Hi Nic,
I don't know your issue. For linux you could change your hard drive from your old pc to your new pc. This should normally work.
If above tryout is not working, you could try this one.
And if that works, then you are using the same operating system as me.
You could try to downgrade the kernel to a 4.19 wich can be performing slightly better.
Another option is burn a dvd with this one.
I don't like that version, but is is downloaded over 560 times.
Good luck !
Last edit: 5 years 4 months ago by Grotius.
5 years 4 months ago #211242 by nic
Hi Grotius,
it`s strange but I have used the same hard disk. I think debian don`t like my new amd gpu. I fixed it already (after 3h .. xD) with the amd firmware.
Thank`s a lot anyway for your answer.
Is the Linux 11 in your opinion better than buster?
Best regards,
Nic
4 years 7 months ago #238638 by LAUSCH
Hi all,
When I ran the Ethercat_installer.sh it end up with the following error message:
cat: /sys/class/net/enp0s25/address: No such file or directory cat: /sys/class/net/enp0s25/address: No such file or directory .. Retrieved MAC adres : .. .. Appending MAC adres to last line of ethercat file /etc/default/ make: Entering directory '/usr/share/ethercat/linuxcnc_ethercat' make[1]: Entering directory '/usr/share/ethercat/linuxcnc_ethercat/src' make[2]: Entering directory '/usr/share/ethercat/linuxcnc_ethercat/src' make[2]: Nothing to be done for 'all'. make[2]: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat/src' make[2]: Entering directory '/usr/share/ethercat/linuxcnc_ethercat/src' make[2]: Nothing to be done for 'all'. make[2]: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat/src' make[1]: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat/src' make: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat' Compiling the linuxcnc-ethercat lcec driver Updating EtherCAT master confiuration modprobe: ERROR: could not insert 'ec_master': Invalid argument failed! Job for systemd-modules-load.service failed because the control process exited with error code. See "systemctl status systemd-modules-load.service" and "journalctl -xe" for details.
$ ip a revealed that my network device is not called enp0s25
following approached solved the issue:
$ sudo ip link set <your network device name> down $ sudo ip link set dev <your network device name> name enp0s25 $ sudo ip link set enp0s25 up $ sudo ip a
Afterwards i ran "Ethercat_installer" again and it executed successfully.
Time to create page: 0.447 seconds
