RTAI with 4.19.152 - Bugs Fixed. Testers Needed
5 years 10 months ago - 5 years 10 months ago #191001 by Vescovo
Your deb files have been installed after a complete removal of the current
linuxcnc
rtai-4.14-174
Using synaptic package manager.
Image file boots but freezes on reboot for a while, then stops indicating reboot.
Managed to get it it to reboot after ^_alt_F1 ^_alt_F7 ^_alt_F1.
I could not copy error files because could not see extra USB drive. The boot is from USB.
Latency-Histogram produced errors
linuxcnc produced errors
g*****@debian-amd64:~/linuxcnc-dev/src$ uname -r 4.19.152-rtai-amd64 g*****@debian-amd64:~/linuxcnc-dev/src$ uname -v #1 SMP PREEMPT Thu Nov 26 19:14:57 GMT 2020 g*****@debian-amd64:~/linuxcnc-dev/src$ latency-histogram --base 25000 --servo 1000000 insmod: ERROR: could not insert module /usr/realtime-4.19.152-rtai-amd64/modules/linuxcnc/threads.ko: Unknown symbol in module exit value: 1 insmod for threads failed, returned -1 See the output of 'dmesg' for more information. while executing "hal loadrt threads name1=t_base period1=25000 name2=t_servo period2=1000000" ("eval" body line 1) invoked from within "eval hal loadrt threads "$args"" (procedure "start_collection" line 7) invoked from within "start_collection" invoked from within "if ![info exists ::LH(start)] { set_defaults config progress "Loading packages" load_packages signal trap SIGINT finish progress "Making g..." (file "/usr/bin/latency-histogram" line 840) g*****@debian-amd64:~/linuxcnc-dev/src$
File Name: linuxcnc_2...2-03.zip
File Size:21.79 KB
Last edit: 5 years 10 months ago by Vescovo. Reason: More info
5 years 10 months ago #191016 by andypugh
Vescovo wrote: Image file boots but freezes on reboot for a while, then stops indicating reboot.
That's a bit strange, the RTAI and LinuxCNC debs were built on a machine with a kernel installed using that .deb, and there were no issues.
That path looks like nonsense, I wonder where it comes from?
5 years 10 months ago - 5 years 10 months ago #191027 by Vescovo
There is an error in the dmesg file named lboot2.log included in zip. I am not versed well enough to comment maybe this is a source of problems. Another strange occurrence is that all of the "Home" folders are greyed out in file manager.
The Computer is a old I7 with 8G of Dram. Is it possible I did something wrong?
Just in case the source install I tried to compiled caused the errors, I rebuilt a new disk from the Linuxcnc ISO 2.8 distribution with a graphical install.
1) Re partitioned USB disk so it has 2 primary partitions
2) Applied the grub bootloader to USB disk
3) Booted from USB
4) dpkg -i linux-image-4.19.152-rtai-amd64.deb
5) dpkg -i rtai-modules-4.19.152_5.2.3-linuxcnc_amd64
6) dpkg -i linuxcnc_2.8.1_amd64. Conflict with existing
7) Synaptic removed Linuxcnc all languages, uspace, and uspace-dev
8) dpkg -i linuxcnc_2.8.1_amd64. Conflict with existing: Successful install
9) latency-histogram --base 25000 --servo 1000000: Produced more errors then before!
10) sudo apt-get update
11) sduo apt-get dist-upgrade
12) latency-histogram --base 25000 --servo 1000000: Produced same error as before!
A RETEST of the USB functions without the previous errors. Did the use of the USB in the other 3 computers make changes? YES IT DOES!!! A repeat situation with a build of USB-2 drive created the same error as above. Following steps 1->5 below did not clear the problem. After USB-2 was booted on the Acer-Veritron with the latency-histogram test successful the USB-2 drive was moved to the ACER-8943G. The problem no longer occurred. Most likely the Environment variables changed? I was not smart enough to make a copy of them beforehand!
The Hang on reboot also disappeared. The reboot hang is similar to the what occurs when the UUID of the swap partition is incorrect. The following steps did NOT correct the problem. The hang occurs because the RTAI scheduler cannot be unloaded.
sudo halrun -U did not unload it.
sudo kill UID did not unload it.
The other changes made to the USB prior to the retest were.
1) Reinstalled ISO on partiton 1, Andy's packages on Partion 2 of USB
2) Reinstalled GRUB on MBR.
3) Edited /etc/fstab on Partiton 2 to reflect new UUID for Swap drive
4) Edited /etc/initramfs-tools/conf.d/remove on Partiton 2 to reflect new UUID for Swap drive
5) sudo update-initramfs -u on Partiton 2 to reflect new UUID for Swap drive
File Name: Acer-8943G...rror.txt
File Size:58.54 KB
File Name: Acer-8943G.log.txt
File Size:58.74 KB
File Name: Acer-8943G.HW.txt
File Size:5.21 KB
Warning: Spoiler!
Last edit: 5 years 10 months ago by Vescovo. Reason: All of a sudden it works!
5 years 10 months ago - 5 years 10 months ago #191121 by Vescovo
Successful boot from SAME USB on Acer Veritron dual core. See Veritron.log.txt file.
File Name: Acer-Veriton.log.txt
File Size:48.04 KB
File Name: Acer-Veritron.HW.txt
File Size:2.57 KB
5 years 10 months ago - 5 years 10 months ago #191128 by Vescovo
File Name: Dell-1525.log.txt
File Size:79.52 KB
File Name: Dell-1525.HW.txt
File Size:3.41 KB
5 years 10 months ago #192109 by mirkap
p@p-pc:~/Pobrane$ sudo uname -a Linux p-pc 4.19.152-rtai-amd64 #3 SMP Sat Dec 12 23:13:39 CET 2020 x86_64 GNU/Linux p@p-pc:~/Pobrane$ linuxcnc LINUXCNC - 2.8.1 /usr/bin/linuxcnc: linia 291: /usr/bin/grep: Nie ma takiego pliku ani katalogu Machine configuration directory is '/home/p/linuxcnc/configs/sim.axis' Machine configuration file is 'axis.ini' Starting LinuxCNC... libnml/cms/tcp_srv.cc 280: bind error: 98 -- Address already in use libnml/cms/tcp_srv.cc 281: Server can not bind the connection socket on port 5005. libnml/rcs/rcs_exit.cc 96: Errors Reported!!! Press ^C to exit. insmod: ERROR: could not insert module /usr/realtime-4.19.152-rtai-amd64/modules/rtai_hal.ko: Invalid module format Realtime system did not load Shutting down and cleaning up LinuxCNC... /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 593: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 626: /usr/bin/pidof: Nie ma takiego pliku ani katalogu /usr/bin/linuxcnc: linia 626: /usr/bin/pidof: Nie ma takiego pliku ani katalogu RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded RTAPI: ERROR: could not open shared memory (No such file or directory) HAL: ERROR: could not initialize RTAPI halcmd: hal_init() failed: -22 NOTE: 'rtapi' kernel module must be loaded rmmod: ERROR: Module hal_lib is not currently loaded rmmod: ERROR: Module rtapi is not currently loaded rmmod: ERROR: Module rtai_math is not currently loaded rmmod: ERROR: Module rtai_sched is not currently loaded rmmod: ERROR: Module rtai_hal is not currently loaded LinuxCNC terminated with an error. You can find more information in the log: /home/p/linuxcnc_debug.txt and /home/p/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
Time to create page: 0.484 seconds
