3 years 3 months ago #275967 by cakeslob
It can be made to work most likely, with SPI. I dont know about the ethernet though, or if the GD-407 will work.
3 years 3 months ago #275981 by scotta
Would Remora work with this ?
www.olimex.com/Products/ARM/ST/STM32-E407/open-source-hardware
The STM32 Remora-EC500 code base would be a very close starting point. The EC500 uses a different version of the F407 so pin assignments would need to be checked.
github.com/scottalford75/Remora-EC500
The following user(s) said Thank You: Cant do this anymore bye all
3 years 3 months ago #275985 by Cant do this anymore bye all
Cheers mate.
What version of STM32Cube would you recommend ?
3 years 3 months ago #276707 by virencq
Hi cakeslob,
I have used your repository github.com/cakeslob/Remora/tree/nucleo_staticZE .
Thanks for your implementation for Nucleo 446ZE.
I am sharing the video for the issue.
In MDI I hit 5 mm, the stepper moves slightly over 5 mm then it retracts to commanded position of 5 mm.
3 years 3 months ago #276746 by 3DPandME
Hi cakeslob!
I'm finally at the wiring and controller stage of my build and so I'm picking this back up.
Still trying to use the Spider king board and big TMC5160s
I put the firmware.bin file on an SD card and popped it into the spider king. Flash led (red one on the core module) flashed on off for a while then stopped. On reboot there is lots of something going to the serial port but none of it is human readable? I used an Arduino to read the pass the serial to a terminal on my pc like you would a UART to usb adapter.
Is 115200 the correct baud rate? I'm connecting to the Rx/tx pins on the raspberry pi connector on the spider king (I remember that it doesn't use the usb ones by default)
How do I debug before trying to connect the SPI?
Cheers for your work!
3 years 2 months ago #276776 by cakeslob
hey viren, add these deadband lines to your ini and hal for each axis. you may need to adjust the values a little
github.com/Expatria-Technologies/remora-...remora-flexi.hal#L90
github.com/Expatria-Technologies/remora-...emora-flexi.ini#L109
Time to create page: 0.409 seconds
